ICQ, problem about receiving files
  • Thread starter Thread starter KLscilevothma
    files
To resolve the issue of not receiving files on ICQ after reinstalling it, users should check their firewall settings and router configurations. It's essential to ensure that the firewall allows traffic through the ports used by ICQ, typically between 1080 and 1802. If a firewall is in use, users need to enable both incoming and outgoing access for the specific port ICQ is using, preferably selecting a port above 1023. If behind a router, enabling port forwarding for the chosen port to the local machine is necessary, often involving Network Address Translation (NAT). Users should avoid placing their computer in the DMZ due to security risks. In ICQ's preferences, users should adjust the Firewall IP settings, with options to use internal, automatic, or external IPs, and configure TCP listen ports for incoming events to a range above 1023. If issues persist, further configuration of the broadband modem may be required.
KLscilevothma
After reinstalled icq in my computer, I can't receive any files from friends. What should I do now ?
I think some settings in Preferences need to be changed in order to solve the problem. Please help.
Computer science news on Phys.org
My first guess would be are you behind a firewall? do you run zone alarm or sygate or anything else of the sort? You're going to have to disable protection for the port that ICQ transfers files on. I believe the ports are 1080-1802, but I'm not sure so there is probably an option to choose which port to use. Choose one above 1023 and enable outgoing and incoming access on your firewall for that port.
My next guess is that you're behind a router or something similar like an external DSL modem. You might have to enable port forwarding for the file transfer port to your machine. most people use NAT for this (network address translation). If you really wanted you could also put yourself in the DMZ, but it dramatically lessens security, so i don't recommend it. The proceddure to set this up is different on every DSL modem/router so you'll have to look at the manual.
if you specify which situation your in (or if it's neither) i could probably give you more help in configuring your router or firewall.
-HBar
-HBar
thanks for your reply
Well I don't think my pc is behind a firewall and I don't run zone alarm or sygate(I fact I don't know what they are). My computer is put in my room. The hard disk was formated about 2 to 3 weeks ago and I reinstalled icq after that. I am now using icq 2003a, which is the same version as the one before I formatted the harddisk. I could receive files without any problem before formatting harddisk.
I am usuing broadband and have a LAN card. I think I don't use firewall/proxy. I think I need to change some settings in icq preferences. I remember last year when I first installed icq, my friend taught me to change something in the setting before I could receive files, but i forget what it was and couldn't find that person in these few days.
In icq, Firewall IP setting, there are 3 options.
1. Always use internal ip
2. icq will determine ip automatically
3. always use external ip (default)
Which one should I choose ?
In proxy setting, I choose Not Using FIrewall.
It sounds like it's your broadband modem that is causing the trouble. What i would do is go to main->connections->user and choose the "Use the following TCP listen ports for incoming events". Enter a range of ports above 1023 like 1050-1055. Then configure NAT on your broadband router to forward all requests for port 1050-1055 to your computer.
-HBar
Thread 'Urgent: Physically repair - or bypass - power button on Asus laptop'
Asus Vivobook S14 flip. The power button is wrecked. Unable to turn it on AT ALL. We can get into how and why it got wrecked later, but suffice to say a kitchen knife was involved: These buttons do want to NOT come off, not like other lappies, where they can snap in and out. And they sure don't go back on. So, in the absence of a longer-term solution that might involve a replacement, is there any way I can activate the power button, like with a paperclip or wire or something? It looks...
I came across a video regarding the use of AI/ML to work through complex datasets to determine complicated protein structures. It is a promising and beneficial use of AI/ML. AlphaFold - The Most Useful Thing AI Has Ever Done https://www.ebi.ac.uk/training/online/courses/alphafold/an-introductory-guide-to-its-strengths-and-limitations/what-is-alphafold/ https://en.wikipedia.org/wiki/AlphaFold https://deepmind.google/about/ Edit/update: The AlphaFold article in Nature John Jumper...
