Solving Pulley Block System Acceleration & Tension
The discussion focuses on solving for acceleration and tension in a pulley block system, specifically addressing the calculation discrepancies when treating the system as a whole versus analyzing individual blocks. The correct acceleration is determined to be 30/7 m/s² after considering the forces acting on the blocks, where the heavier block's downward force must be subtracted from the lighter block's upward force. A misunderstanding arises regarding the addition of forces, as gravity acts on both blocks in opposite directions, necessitating subtraction to find the net force. The importance of accurately drawing free body diagrams and recognizing the equal and opposite tensions in the rope is emphasized for clarity in problem-solving. Overall, understanding the physical interactions in the system is crucial for correctly applying Newton's laws.
Elena14
1. Homework Statement
FInd acceleration and tension. Take g=10m/s^2
2. The attempt at a solution
By drawing the free body diagrams of every block and simultaneously solving all the equations, I got the answer acceleration= 30/7 m/s^2, which is also correct.
But when I try to treat all the pulleys and blocks as one system to get the acceleration, I get a different answer.
f=ma
⇒ 40g+10g= 70 * a (since weight of 40 kg block and 10 kg block are the only forces acting downwards) ⇒ a=500/70 m/s^2
Somebody told me that I should have rather subtracted 40g and 30 g, so that would be 40g-10g=70a ⇒a=30/7 which happens to be the right answer.
But I don't understand why will we subtract the force vectors if they are all acting in the same direction ;ie, downwards. Where am I wrong with the second approach?
Imagine one single pulley with two weights, 10 kg and 10 kg. Will the acceleration be (10+10) g / 20 or will it be (10-10) g / 20 ?
20 g according to my logic. Since, weight( a force vector) of the bodies is in the downward direction, we will add the vectors together to get the total weight and hence the acceleration=mg=(10+10)g.
Alright I get it now, when gravity acts on those blocks ,both will have acceleration in opposite directions; the 40 kg block will move downward being heavier and the lighter block will be forced to move up and hence we subtract their weight.(mg)
Thank you so much.
Likes BvU
(Especially for later exercises) it is important to clearly identify the physical role of the rope: you should have seen that already when "drawing the free body diagrams of every block": the tensions at the two ends of a straight rope are equal and opposite forces. When the chord is run over a pulley, in the no friction case the magnitudes remain the same but the directions change.
But for the straight sections - again - the tensions at each of the two ends are equal and opposite.
As a simple trick you can (imagine to) cut each straight section halfway and apply two equal and opposite forces to keep the loose ends in place.
