QM 1-D Harmonic Oscillator Eigenfunction Problem
tis
A particle of mass m moves in a 1-D Harmonic oscillator potential with frequency \omega.
The second excited state is \psi_{2}(x) = C(2 \alpha^{2} x^{2} + \lambda) e^{-\frac{1}{2} a^{2} x^{2}} with energy eigenvalue E_{2} = \frac{5}{2} \hbar \omega.
C and \lambda are constants. Show that the constant \lambda is not arbitrary.
NOTE: \int_{-\infty}^{\infty} e^{-\frac{1}{2} a x^{2}} dx = \sqrt{2\pi / a}, a > 0.
That I can think of: TISE, normalization condition for wavefunctions.
I assume there's a solution in substituting into the time-independent Schrodinger Equation and solving for \lambda, but the equation seems very difficult. And I have no idea how to utilize the hint provided; everything I've tried (normalization condition, etc.) just gives a dependence on C. I've scoured my textbooks with no luck, their only relevant info is using ladder operators and other methods to produce eigenfunctions.
Just after a point in the right direction. Thanks in advance for your help!
Your idea to substitute this into the TISE seems like a good start. All you will have to do is take derivatives and rearrange some terms, and you will end up with an equation which determines lambda. Give it a try.
Figured it out. Take the ground state of the harmonic oscillator \psi_{0} = A e^{-\frac{1}{2}\alpha^{2} x^{2}} and use the orthogonality condition \int_{-\infty}^{\infty} \psi_{0}^{*} \psi_{2} \ dx = 0.
From there just expand, cancel out A* and C, and solve the integrals with integration by parts and the hint provided. Eventually you come to 0=2\alpha^{2}\frac{\sqrt{\pi}}{2\alpha^{3}}+\lambda\frac{\sqrt{\pi}}{ \alpha }, hence \lambda=-1.
Thread 'Need help understanding this figure on energy levels'
This figure is from "Introduction to Quantum Mechanics" by Griffiths (3rd edition). It is available to download. It is from page 142. I am hoping the usual people on this site will give me a hand understanding what is going on in the figure. After the equation (4.50) it says "It is customary to introduce the principal quantum number, ##n##, which simply orders the allowed energies, starting with 1 for the ground state. (see the figure)" I still don't understand the figure :( Here is...
Thread 'Understanding how to "tack on" the time wiggle factor'
The last problem I posted on QM made it into advanced homework help, that is why I am putting it here. I am sorry for any hassle imposed on the moderators by myself. Part (a) is quite easy. We get $$\sigma_1 = 2\lambda, \mathbf{v}_1 = \begin{pmatrix} 0 \\ 0 \\ 1 \end{pmatrix} \sigma_2 = \lambda, \mathbf{v}_2 = \begin{pmatrix} 1/\sqrt{2} \\ 1/\sqrt{2} \\ 0 \end{pmatrix} \sigma_3 = -\lambda, \mathbf{v}_3 = \begin{pmatrix} 1/\sqrt{2} \\ -1/\sqrt{2} \\ 0 \end{pmatrix} $$ There are two ways...
