QM expectation value relation <x^n>, <p^n>
sensou
I need to calculate <x^n> and <p^n> for psi(x)=exp(-ax^2/2)
for n even.
For <x^n>:
<x^n>=integral(exp(-ax^2)*x^n )dx from -inf to +inf
then i use integration by parts to get an infinite series and i use a formula to find the finite sum of the series
=[exp(-ax^2)*x^(n+1)/((n+1-2a*(n+1)^2)] with limits -infinity to +infinity
i don't think this is sufficient as i believe the answer should result in a constant and when i use this to work out <x^2>, i can't get a finite answer. I am not sure of another way to work through this question.
For <p^n> i have shown that for n odd, this vanishes, but for n even i am not sure what the answer is. I would appreciate any help or suggestions on where to start with this question, thanks.
Here's a trick...What happens if n=odd integer for \langle \hat{x}^{n} \rangle ...?
Daniel.
P.S. I'm sure you did gaussian integrals in statistical physics seminar.
for n even.
For <x^n>:
I don't see how you can get an *infinite* series!
First, write down the result for the case n=0. Then, consider the case with n=2. after doing integrations by parts, you may write the result in terms of the n=0 expression.
Now do it with n=4 which, after integrations by parts, may be written in terms of the result of n=2. At that point, the generalization should be obvious. The result is of the form "a" raised to a certain power times a factorial term.
Thanks for your quick replies. I am now able to get the answer :smile:
I should have done it that way from the start but for some reason that infinite series thing led me on a bit.
Thanks for all the help.
I just realized that i haven't been able to get the <p^n> part right where p=-i(h-bar)d/dx
i get <p^2>=(h-bar)^2 *a/2*sqrt(pi/a)
<p^4>=(-3/4)*(h-bar)^4 *a^2*sqrt(pi/a)
<p^6>=(-165/8)*(h-bar)^6 *a^4*sqrt(pi/a)
<p^8>=(4605/16)*(h-bar)^8 *a^6*sqrt(pi/a)
And this doesn't give me a nice relationship for <p^n>
i realize that p^n where n is odd =0.
I think i must have done something wrong with the maths somewhere, but i can't find where. And i am 90% sure that the <p^2> is correct but i don't know about the others.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
