QM, show a relation (velocity of a free particle related)
fluidistic
Hi guys, I'm stuck at some step in a QM exercise. Here it is: Consider a free particle of mass m that moves along the x-axis (1 dimensional). Show that ##\frac{dA}{dt}=\frac{2 \hbar ^2}{m^2}\int \frac{\partial \psi}{\partial x} \frac{\partial \psi ^*}{\partial x}dx=\text{constant}##.
Where ##A(t)=\frac{i\hbar}{m} \int x \left ( \psi \frac{\partial \psi ^*}{\partial x} - \psi ^* \frac{\partial \psi}{\partial x} \right ) dx##.
In fact ##A(t)=\frac{d \langle x^2 \rangle}{dt}## but I already showed that it's worth the integral I just wrote (the result matches the answer).
(1)Schrödinger's equation: ##i\hbar \frac{\partial \psi}{\partial t}=\frac{(p^2 \psi)}{2m}##, where p is the momentum operator and worth ##-ih \frac{\partial \psi}{\partial x }##.
Taking the complex conjugate on both sides, I get that ##\psi ^*## satisfies:
(2) ##-i \hbar \frac{\partial \psi ^*}{\partial t}=\frac{p^2 \psi ^*}{2m}##
From (1) I get that
(3) ##\frac{\partial \psi}{\partial t }=-\frac{i(p^2\psi)}{2m\hbar}##
and
(4)##\frac{\partial \psi ^*}{\partial t }=\frac{i(p^2\psi ^*)}{2m\hbar}##
##\frac{dA(t)}{dt}= \frac{d}{dt} \left [ \frac{i\hbar}{m} \int x \left ( \psi \frac{\partial \psi ^*}{\partial x} - \psi ^* \frac{\partial \psi }{\partial x} \right ) dx \right ]= \frac{ih}{m} \int x \underbrace{ \frac{d}{dt} \left ( \psi \frac{\partial \psi ^*}{\partial x} - \psi ^* \frac{\partial \psi }{\partial x} \right ) dx } _{K}## (line 5)
I try to calculate K first.
##K=\frac{\partial \psi}{\partial t} \frac{\partial \psi ^*}{\partial x}+\psi \frac{\partial ^2 \psi ^*}{\partial x^2}- \left ( \frac{\partial \psi^*}{\partial t} \frac{\partial \psi }{\partial x} + \psi ^* \frac{\partial ^2 \psi }{\partial x ^2}\right )##. (line 6)
Now I use (3) and (4) to get ##K=-\frac{i}{\hbar} \frac{(p^2\psi)}{2m} \frac{\partial \psi ^*}{\partial x}+\psi \frac{\partial ^2 \psi ^*}{\partial t \partial x }- \left ( \frac{i}{\hbar} \frac{(p^2 \psi ^* )}{2m} \frac{\partial \psi }{\partial x }+ \psi ^* \frac{\partial ^2 \psi}{ \partial t \partial x } \right )## (line 7)
Here I assume that ##\frac{\partial ^2 \psi }{\partial t \partial x }=\frac{\partial ^2 \psi}{\partial x \partial t}##.
If so, I get ##K=-\frac{i}{\hbar} \frac{(p^2 \psi)}{2m} \frac{\partial \psi ^*}{\partial x}+\psi \frac{\partial ^2 \psi ^*}{\partial x \partial t}- \left ( \frac{i}{\hbar} \frac{(p^2 \psi ^*)}{2m} \frac{\partial \psi}{\partial x} + \psi ^* \frac{\partial ^2 \psi }{\partial x \partial t} \right )## (line 8)
Now I use (3) and (4) to get ##K=-\frac{i}{\hbar} \frac{(p^2 \psi)}{2m} \frac{\partial \psi ^*}{\partial x} + \psi \frac{\partial}{\partial x} \left [ \frac{i(p^2 \psi ^*)}{2m \hbar} \right ] - \{ \frac{i}{\hbar} \frac{(p^2 \psi ^*)}{2m\hbar} \frac{\partial \psi}{\partial x} + \psi ^* \frac{\partial }{\partial x } \left [ -\frac{i (p^2 \psi)}{2m\hbar} \right ] \} ## (line 9)
I factor out i/(2m hbar) to get ##K=\frac{i}{2m\hbar} \{ \psi \frac{\partial }{\partial x} (p^2 \psi ^*) - \frac{\partial \psi ^*}{\partial x} (p^2 \psi ) - \frac{\partial \psi }{\partial x} (p^2 \psi ^*) -\psi ^* \frac{\partial }{\partial x} (p^2 \psi) \} ## (line 10)
Now I replace ##p^2## by ##-\hbar ^2 \frac{\partial ^2 }{\partial x^2}## to get ##K=-\frac{i\hbar}{2m} \left ( \psi \frac{\partial ^3 \psi ^*}{\partial x^3} - \frac{\partial \psi ^*}{\partial x} \frac{\partial ^2 \psi }{\partial x^2} - \frac{\partial \psi}{\partial x} \frac{\partial ^2 \psi ^*}{\partial x^2} - \psi ^* \frac{\partial ^3 \psi}{\partial x^3} \right ) ## (line 11)
Now I replace the value of K into where I took it (that is, line 11 into line 5), to get ##\frac{dA(t)}{dt} = \frac{\hbar^2}{2m^2} \int x \left ( \psi \frac{\partial ^3 \psi ^*}{\partial x^3} - \frac{\partial \psi ^*}{\partial x} \frac{\partial ^2 \psi }{\partial x^2} - \frac{\partial \psi}{\partial x} \frac{\partial ^2 \psi ^*}{\partial x^2} - \psi ^* \frac{\partial ^3 \psi}{\partial x^3} \right ) dx##. (line 12).
This is where I'm stuck. I thought about integration by parts, but I'm not seeing anything nice.
I've rewritten ##\frac{dA(t)}{dt}## as ##\frac{\hbar^2}{2m^2} \int x \left [ \frac{\partial }{\partial x} \left ( \psi \frac{\partial ^2 \psi ^* }{\partial x^2} \right ) -2 \frac{\partial \psi}{\partial x} \frac{\partial ^2 \psi ^*}{\partial x^2 } - \frac{\partial }{\partial x} \left ( \psi ^* \frac{\partial ^2 \psi}{\partial x^2} \right ) \right ] dx##. I'm still totally stuck.
I've been extremely careful and what I wrote in latex contains no typo error. All is exactly as in my draft so any mistake/error you see, it's not a typo but an algebra one that I made.
Any help is greatly appreciated, I really want to solve that exercise. Thanks :)
Check the sign of the last term on the right. Otherwise, things look good to me up to this point. After substituting for p2 I think you have the right idea to continue with some integration by parts.
Oh thank you very much TSny, I didn't see this sign mistake. I fixed it and in consequences this changes all the following lines.
I've reached the result! I had to integrate by parts twice for an integral and once for another. I also had to assume that ##x\frac{\partial \psi ^*}{\partial x} \frac{\partial \psi}{\partial \psi} \big | _{-\infty}^\infty## is worth 0 (and another 2 similar relations), which isn't that obvious to me. I mean I have a big feeling that it's worth 0 but I'm not really sure why. I know that ##\frac{\partial \psi}{\partial x}## and ##\frac{\partial \psi ^*}{\partial x}## must tend to 0 at infinities but if I multiply their product by x, then I'm not really sure.
I also have to show that ##\frac{dA(t)}{dt}## is constant. I guess I just have to derivate it with respect to time and see that it's worth 0... I'll do it, I don't think this will be hard nor that long.
All in all the problem was extremely lengthy in terms of algebra!
Thread 'Need help understanding this figure on energy levels'
This figure is from "Introduction to Quantum Mechanics" by Griffiths (3rd edition). It is available to download. It is from page 142. I am hoping the usual people on this site will give me a hand understanding what is going on in the figure. After the equation (4.50) it says "It is customary to introduce the principal quantum number, ##n##, which simply orders the allowed energies, starting with 1 for the ground state. (see the figure)" I still don't understand the figure :( Here is...
Thread 'Understanding how to "tack on" the time wiggle factor'
The last problem I posted on QM made it into advanced homework help, that is why I am putting it here. I am sorry for any hassle imposed on the moderators by myself. Part (a) is quite easy. We get $$\sigma_1 = 2\lambda, \mathbf{v}_1 = \begin{pmatrix} 0 \\ 0 \\ 1 \end{pmatrix} \sigma_2 = \lambda, \mathbf{v}_2 = \begin{pmatrix} 1/\sqrt{2} \\ 1/\sqrt{2} \\ 0 \end{pmatrix} \sigma_3 = -\lambda, \mathbf{v}_3 = \begin{pmatrix} 1/\sqrt{2} \\ -1/\sqrt{2} \\ 0 \end{pmatrix} $$ There are two ways...
