Energy Transfer in Different Scenarios
  • Thread starter boboclown
  • Tags
    Energy
In summary, the conversations revolve around calculations involving heat energy and temperature changes. Some involve the release of energy, while others involve the absorption of energy. The equations used include heat capacity, heat of fusion, and heat of vaporization. The key concept is that heat gained is equal to heat lost in a system, and the change in temperature can be calculated using the given values.
boboclown
a cup of coffee (140g) cools from 75 degrees C down to 20. degrees C. how much energy does it release to the surroundings? answer in J
suppose dutring volleyball practice, you lost 2.0 lbs of water due to sweating. if all of this water evaporated, how much energy did the water absorb from your body? answer in kJ.
suppose during a lab that 65kJ of energy was transferred to 450 g of water at 20C. what would be the final temperature of the water? answer in C
the heat capacity of solid iron is 0.447 J/g degrees C. If 65kJ was transferred to a 450 g chunk of ioron at 20. C what would be the final temperature?
a serving of cheezits releases 130kcal when digested by your body. if this same amount of energy was transferred to 2.5kg of water at 27 C what would the final temperature be?
if 130kcal was transferred to 2.5kg of water at its boiling point, what fraction of the water would be vaporized?
suppose a bag full of ice (450g) at 0.0 C sits on the counter and begins to melt to a liquid state. how much energy must be absorbed by the ice if 2/3 of it melted?
Energy constants
334 J/g heat of fusion
2260 J/g heat of vaporization
2.1 J/g heat capacity of solid water
4.18 J/g heat capacity of liquid water
If you could show work with answer that would be very apreciated as i wasnt there the day when he lectured us on how to do this. an explanation of the problems would be awesome too!
i assume that you multiply the mass times the heat capacity and that all equals the energy (Q). but i don't know what to do then... there is something I am missing
These are all about heat balance. Heat gained = heat lost (by different parts of the system). Heat = m*c*delta T.
delta T?
Change in temperature. Like in
delta T = Tfinal - Tinitial = 75 - 20 = 55 deg C
oh ok ty
What is Quantitive Energy?
Quantitive energy is a term used to describe the measurement and calculations of energy in different forms, such as kinetic, potential, and thermal energy.
What are the units used to measure energy?
The most common units used to measure energy are joules (J) and calories (cal), with joules being the standard unit in the International System of Units (SI).
How do you calculate the total energy of a system?
The total energy of a system can be calculated by adding the kinetic energy and potential energy of all objects in the system. The formula for total energy is: E(total) = E(kinetic) + E(potential).
What is the conservation of energy principle?
The conservation of energy principle states that energy cannot be created or destroyed, only transformed from one form to another. This means that the total energy in a closed system remains constant.
What are some common examples of quantitive energy problems?
Some common examples of quantitive energy problems include calculating the speed of a moving object based on its kinetic energy, determining the amount of work done by a force on an object, and finding the change in potential energy of an object as it moves between different heights.
