Can DC Motors Function Without a Commutator?
  • Thread starter Thread starter GeekyGuy
    Dc Motors
DC motors can function without a commutator by utilizing brushless designs, where transistors manage the switching of magnetic poles instead of brushes. Brushless DC motors, commonly found in computer fans, employ permanent magnets for the armature. Universal motors can operate on both AC and DC, blurring the lines between motor types due to their construction. These motors offer advantages like high startup torque and speed control, making them preferable in certain applications. The discussion highlights the evolving technology in motor design, emphasizing the role of electronic controllers in modern motors.
GeekyGuy
I've been pondering over this for a while. Is it possible to make a DC motor that does not require a commutater.
Is it possible to make a Motor output a DC voltage without commutation? I don't fully understand your question.
Suer
Look at brushless DC motors like used on some computer fans - the switching of north/south poles on the stator is handled by transistors that switch back and forth instead of brushes and the armature is permanent magnets.
If you take a universal motor like used in a corded power drill, it does run on AC current from the wall but will also run on DC because its really just a DC motor with the stator and armature wound in series. Sure it has brushes that wear out, but its still cheap to build and has great startup torque and speed control that a shaded-pole AC induction motor couldn't touch and is why its used.
So sometimes the distinctions between what is considered an AC or a DC motor can be blurred somewhat by their operation and not just the power source.
Thanks. :cool: A motor that uses an intelligent electronic controller. I never heard of that before, but it sounds pretty cool.
Thanks again.
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
