Question about integral and natural log
JamesGoh
Find the integral to the following expression
\int\frac{1}{x-1}dx
\int udv = uv - \int vdu
\int\frac{1}{x}dx = ln(x)
Given the information above, would a correct answer to this problem be ln(x-1) ? If not, what am I doing wrong ?
thanks
how non need to use int by parts a simple substitution will do, ln(x-1) is correct
if you don't show what you doing (your steps it woudl eb hard to tell what was going wrong as well ;)
oh i just realized if you use substitution of variable u=x-1, it makes it easy to show that integral of 1/(x-1) is ln(x-1) :)
good guess, is that all you need?
\int\frac{1}{x-1}dx
thanks
You can attack the problem as follows
let F(x)=\int\frac{1}{x-1}dx
From then on make substitution x=x+1
which yields
F(x+1)=\int\frac{1}{x}dx
Find out this integral which is quite obvious ( do not forget to add a constant to it )
since what you found is F(x+1) now re-substitute x=x-1
yeah pretty much. i worked it out myself using the substituiton and it came out fine
agree, would always use a different variable to represent the substitution eg. u = x-1, then du = dx
