Questions About Dry Dock Ship Launching Answered
  • Thread starter Thread starter Kramjit
    Ship
Dry dock ship launching typically uses wooden structures to prevent damage to the ship's paint coat. Ships rest on cradles that slide on greased rails, minimizing direct contact with the wood. Concerns about potential scratches to the paintwork are addressed, with assurances that damage is rare. Some participants suggest exploring materials with lower friction coefficients to further reduce any risk. Advances in coating technology over the years have likely improved the durability of finishes used on ships today.
Kramjit
Hi!
I saw from youtube clips that dry dock ship launching use these wooden(?) contraptions. Do they cause damage to the paint coat of the ships?
Thanks
No that's why you use wood.
The boats don't generally slide on the wood, the sit on cradles that slide on greased rails.
So you are saying that there is not a slightest damage to the coating in all cases?
Thanks
Thanks
What do you propose that they use to cause LESS damage?
Perhaps we could use a material with low coefficient of friction as a material for the ramp, as described by Mr./Mdm mgb_phys. Eliminate also, altogether, the use of grease.
Fundamentally, I just would like to know if existing methods scratch the paintwork.
Thanks
It's been over 30 years, but when i had some involvement with boat building(intracoastal, and river pushboats) the below waterline coatings, were mixes of paints and resins, and some flourlike metals, that had to be continually stirred with a air motor while in the paintpot.
These finishes, when cured, were as hard or harder than the metal they covered.
Not sure but i would think that finishes today might be even better.
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
9K
