Questions in [ motion in two dimensions ]
The discussion addresses key concepts in motion in two dimensions, focusing on instantaneous and average velocity, projectile motion, and forces acting on a projectile. Instantaneous velocity refers to the speed at a specific moment, while average velocity is calculated over a distance and time interval. A projectile launched at an angle experiences constant acceleration in the vertical direction due to gravity, while its horizontal acceleration remains zero if air resistance is negligible. As a projectile follows a parabolic trajectory, its speed and vertical component of velocity change, but its horizontal component of velocity remains constant. Understanding these principles is essential for analyzing motion in two dimensions.
mo3az
questions in [ motion in two dimensions ]
q. [ .. if you know the position vectors of a particle at two points along its path and also know the time interval during which it moved from one point to the other m can you determine the particle's instananeous velocity ? its average velocity ? Explain.
q. [.. a projectile is launched at some angle to the horizontal with some initial speed vi and air resistance is negligible . is the projectile a freely falling body ? what is its acceleration in the vertical direction ? what is its acceleration in the horizontal direction ?
q. [ ..O stat which of the following quantities , if any , remain constant as a projectile moves through its parabolic trajectory :(a) speed (b) acceleration (c) horizontal compnent of velocity (d) vertical component of velocity .
Think about it a little.
1) Instantaneous velocity is it's velocity at any given point right at that instant. Average is it's velocity over some distance for some amount of time.
2) If you throw a ball, after you throw it, what forces are acting on it? And what direction do those forces pull? there is no acceleration without a force.
3) You need to look at each of those quantities and think about what happens to a ball when thrown. Remember, after the ball leaves your hand, only certain forces are working on it. Acceleration will only change due to a force. Velocity will only change due to an acceleration.
Thank u a lot ,,
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
