Quick & Easy Problem: Pushing Box Up Ramp
  • Thread starter Thread starter Tom McCurdy
The discussion revolves around calculating the work done when pushing a box up a ramp with a specified length and angle. Key considerations include the horizontal force applied, the normal force, friction force, and forces acting against gravity. The user initially seeks to understand the work done against friction and gravity, as well as the kinetic energy imparted to the box. The conversation shifts when the user realizes the issue was due to using radians instead of degrees on their calculator. This highlights the importance of ensuring correct calculator settings when solving physics problems.
Tom McCurdy
Alright I am just trying to get a concept for a problem that I am doing
If you have a horizontal force of say X pounds and you want to push a box up a ramp that has a length of L with and angle of theta. How much work would you have done if you push the box the full length of L up the ramp?
What is the magnitude and direction of the normal force? What is the magnitude and direction of the friction force? What is the magnitude and direction of the force working against gravity? What is the net force? What is the work done against friction? What is the work done against gravity? What is the work done in giving the box kinetic energy?
AM
nevermind
sorry guys
Radian mode on the calculator instead of degree
