Rate of Change - Just checking
kevinr
[SOLVED] Rate of Change - Just checking
Sand is poured into a conical pile with the height of the pile equaling the diameter of the pile. If the sand is poured at a constant rate of 5m^3/s at what rate is the height of the pile increasing when height is 2 meters.
v = (1/3)\pi r^2
r' = h' / 2 (i think this is right - not sure)
So i got
v' = (1/3)\pi (2rr'h + r^2h')
So i have 2 unknowns r' and h'. Since we can make the connection that r' = h'/2 i replace that in the equation and get:
v' = (1/3)\pi (2r(h'/2)h + r^2h') ->
r = 1
h = 2
SO:
v' = (1/3)\pi (2h' + h') ->
h' = 5/\pi
Im not sure if this answer is right but if you can please check over my work, i would appreciate it.
Thanks!
It would have been better to have clearly stated somewhere that v'= 5, but it's obvious that you did use that. Yes, that is the correct answer.
Sorry i thought it was in the problem question i posted.
Well thanks!
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
