Rate of leakage from box
  1. Feb 5, 2013 #1
    A cubic container with sidelength l has a small hole with cross sectional area a (a<<l). The gas has density ρ and pressure P. Find the initial rate of gas leakage given that the outside pressure is 0.
    2. Relevant equations
    The question mentions the formula p=ρc2/3 so I know I have to use this.
    3. The attempt at a solution
    Assume that 1/3 of the particles are moving in a direction towards the hole. Any molecule in a cylinder of base a and length c will leave the hole in one second so is the leakage rate av/3, and then I can substitute out c with the formula? Is this the correct answer?
  3. Feb 5, 2013 #2
    Simon Bridge
    Not bad - but your result does not appear to take the pressure difference into account.
    I'd have wanted to see that explicit - can you explain what your equations mean and how you are using them.
    I suspect you have it right, but cannot tell exactly from what you've written down so far.
Similar Discussions: Rate of leakage from box
  1. Box Hangs From Rope (Replies: 12)
Loading...
