What Percent of Final Charge Does a Capacitor Reach After 4.5 Time Constants?
After 4.5 time constants in an RC circuit, a capacitor reaches approximately 98.2% of its final charge. The formula used to calculate the charge is Q = Qo [1 - e^(-t/RC)], where Qo is the initial charge. By substituting t with 4.5RC, the expression simplifies to e^(-4.5). This calculation confirms that the capacitor is nearly fully charged at this point. Understanding this concept is crucial for analyzing charging behavior in RC circuits.
itryphysics
Consider an RC circuit in which a capacitor is being charged by a battery connected in a circuit. Initially the capacitor is uncharged. Then the switch is closed.
After a time equal to 4.5 time constants, what percent of the final charge is present on the capacitor?
Q = Qo [1 - e^ (-t/RC)]
I picked a value of 100 for Qo
so
Q= 100 [1 - e^ (-t/4.5)]
my approach was going to be to find Q and then see wht percent that is of the initial charge Qo
but I don't know wht to put in for the time "t"
please help me out
I think you would take t = 4.5RC
so for the expression e^(-t/RC) I do e^(-4.5) ?
4.5 time constants means a time of 4.5*R*C.
R*C comes out in units of time.
Yes that should do it.
Awsome! Thank you so much!
