RC time Circuit; charge of capacitor as a function of time derivation
The discussion focuses on deriving the equations for the charge of a capacitor in RC circuits, specifically the charging and discharging equations. The user attempts to derive the charging equation but realizes they may have set up the problem incorrectly, particularly in assuming the potential drop across the resistor equals that across the capacitor. They express confusion about the relationship between the voltage across the capacitor and the resistance in the circuit. The conversation emphasizes the importance of correctly understanding the physical setup of the circuit to derive the equations accurately. Clarification on the potential gain across the battery and its relationship to the circuit components is sought.
sobie925
Hey guys! New to physicsforums. I wanted to ask a more conceptual question regarding RC time Circuits. I spent some time trying to derive the equations, and I feel like I'm not setting up the problem correctly. Here's my attempt:
Solutions according to profecssor:
1) ##q_{charge}(t)=C\epsilon(1-e^{-\frac{t}{\tau}})##
2) ##q_{discharge}(t)=q_{0} e^{\frac{-t}{\tau}}##
my attempt at solution 1
##q##-charge on capacitor
##R##-Resistance encountered in circuit
##C##-Capacitance of capaticor
##\epsilon##-Electromotive Force of battery
##t## -time since capacitor began charging
##\tau## - ##RC##
##i## -current
##C=\frac{q}{\epsilon}##
∴##q=C\epsilon##
##\epsilon=iR=\frac{dq}{dt}R##
∴##q=RC\frac{dq}{dt}=\tau\frac{dq}{dt}##
∴##\frac{1}{q}\frac{dq}{dt}=\frac{1}{\tau}##
∴##\int_0^t \frac{1}{q}\frac{dq}{dt} dt=\int_0^t \frac{1}{\tau} dt##
∴##\int_{q(0)}^{q(t)} \frac{dq}{q}=\int_0^t \frac{1}{\tau} dt##
∴##ln(q(t))-ln(q(0))=\frac{t}{\tau}##
∴##ln(\frac{q(t)}{q(0)})=\frac{t}{\tau}##
∴##e^{\frac{t}{\tau}}=\frac{q(t)}{q(0)}##
∴##q(t)=q(0)e^{\frac{t}{\tau}}##
So it's here that I'm like "I guess ##q(0)=c\epsilon## just for the sake of looking more like the professor's solution" <I realize how stupid this is... lol
∴##q(t)=C\epsilon e^{\frac{t}{\tau}}##
There must be something that I'm just totally missing here. The math seems right, so I'm thinking it's the set-up that I'm missing.
Any help is appreciated! Thank you!
You have assumed that the potential drop across the resistance is the same as that across the capacitor. Is this true or can you think of something else that is more physical?
Alright, so I started off on the wrong part. So, I need to derive ##V_{C}(t)=\epsilon(1-e^{\frac{-t}{\tau}})## (This was written on the paper our professor gave us, so as of now it doesn't really mean anything to me.)
So, ##V_{C}=iR##. The current is the same as the current we've been dealing with, but what R is this equation referring to?
Let us start studying the charging circuit: Draw the circuit. What will be the potential drop across the capacitor and resistor respectively? What is the potential gain across the battery? How are those related?
For the discharging circuit: it is the same just without the battery.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
