Refraction in a Glass Cylinder with just 1 Number
The discussion centers on solving a refraction problem involving a light ray incident on a glass cylinder, where the height is given as h = R/9. Participants emphasize the importance of using Snell's law to determine the angle of refraction, noting that the angle must be measured relative to the normal of the surface. There is confusion about the relevance of the dimensions provided, with suggestions to simplify the problem by setting R=1 and h=1/9. Clarifications are sought regarding the point of incidence on the cylinder and the orientation of the light ray. The geometry of the situation is highlighted, indicating that a right triangle can be formed to express the angle needed for calculations.
Phoenixtears
The figure shows a light ray incident on a glass cylinder where h = R/9. At what angle α will the ray be refracted?
(Image Attached)
n(sin(theta))= N(sin(THETA))
I'm not sure how to attack this problem. I've thought of using Snell's law:
1 sin (90) = 1.52 sin (THETA)
But I stopped myself mid-equation because then the R/9 is useless. I have decided to make R= 1 and then h= 1/9 (just to make things simple. I drew the picture and then extended out the refracted arrow, trying to figure out a way to use geometry, but I just can't place it.
Can anyone help me out?
Thanks in advance!
~Phoenix
The attachment is pending approval so I can't see your picture yet. But you will need Snell's law since the refraction will depend on the materials index. Are there any other parameters? Can you describe were on the cylinder the light is striking? End or round side? Aimed through the axis or offset by some distance?
Remember Snell's law applies to angles relative to the normal of the surface. You have a 90deg in your formula which indicates the light is tangent to the surface. If the light strikes perpendicular to the surface you will have no refraction and angle = 0. If tangent to the surface it doesn't even cross the surface.
Hint: what angle does the normal make, with respect to horizontal?
Then normal is perpendicular to the surface. In the case of the cylinder it will be in the direction of a line through the axis of the cylinder and the point where the light hits the surface. You'll find that the radius and the height h above the center form sides of a right triangle. You can use trig to express the angle.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
