Relativistic electron in static electric field
Hybird
Electron placed in static electric field \vec{E} = -\Psi\hat{x} , its initial velocity is 0. Calculate V(t).
F_{e}=\frac{d}{dt}p(t)
p(t) = \gamma(t)mv(t)
Gamma is 1/sqrt(1-v^2/c^2) of course
This is how I go about it and want to know if I'm on the right track.
i) First you multiply the electric field by the charge of an electron to get:
F_{e} = \frac{d}{dt}p(t) = e\Psi
ii) Then you integrate wrt time to get:
p(t) = e\Psit
iii) Then you relate momentum to velocity by:
p(t) = \gammamv(t)
iv) Finally you solve for V(t) from the above equation, expressing gamma explicitly I get the following formula:
v(t) = \frac{e{\Psi}t}{m}*\frac{1}{ {\sqrt{1+ {\frac{ e^{2}{\Psi}^{2}t^{2} }{ m^{2}c^{2} }} }} }
Does this seem to be the right method? I have to integrate this eventually to get x(t)..
This doesn't seem right because V(t) is unbounded as t goes to infinity and thus we would pass the speed of light correct?
No. This expression
approaches c as t goes to infinity.
So maybe I am on the right track. Just curious, how do you get that limit? Do you have to binomial expand the square root?
I don't know what you mean by that, but probably not. After you do about 100 million of these kinds of limits, you just start to smell the approach. In this case, I just know that the other stuff under the radical will be much larger than 1, so I ignore the 1. The rest is straightforward. I think the more mathy way to do it is to divide top and bottom by t or something ...
Thread 'Need help understanding this figure on energy levels'
This figure is from "Introduction to Quantum Mechanics" by Griffiths (3rd edition). It is available to download. It is from page 142. I am hoping the usual people on this site will give me a hand understanding what is going on in the figure. After the equation (4.50) it says "It is customary to introduce the principal quantum number, ##n##, which simply orders the allowed energies, starting with 1 for the ground state. (see the figure)" I still don't understand the figure :( Here is...
Thread 'Understanding how to "tack on" the time wiggle factor'
The last problem I posted on QM made it into advanced homework help, that is why I am putting it here. I am sorry for any hassle imposed on the moderators by myself. Part (a) is quite easy. We get $$\sigma_1 = 2\lambda, \mathbf{v}_1 = \begin{pmatrix} 0 \\ 0 \\ 1 \end{pmatrix} \sigma_2 = \lambda, \mathbf{v}_2 = \begin{pmatrix} 1/\sqrt{2} \\ 1/\sqrt{2} \\ 0 \end{pmatrix} \sigma_3 = -\lambda, \mathbf{v}_3 = \begin{pmatrix} 1/\sqrt{2} \\ -1/\sqrt{2} \\ 0 \end{pmatrix} $$ There are two ways...
