Reparametrization to find arc length
llooppii
Reparametrize the curve with respect to arc length measured from the point where t=0 in the direction of increasing t.
r(t) = [e^(2t)cos(2t)]i+2j+[e^(2t)sin(2t)]k
i know that the derivative of the arc length with respect to t = magnitude of the derivative of r(t).
I found the derivative and found the magnitude, but am basically lost as of there.
start by finding the arc length as function of t
Let s(t) be the arc length, and I'm sure Ur calculus textbook will have the formula of arc length..
In fact you can easily "derive" the formula with pythagorus theorem and riemman sum in mind.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
