Calculating Voltage Difference in a Parallel and Series Circuit
The discussion focuses on calculating the voltage difference across the third bulb in a circuit with three 60W, 120V bulbs, where two are in parallel and one is in series with a 120V battery. The total circuit resistance is determined by combining the resistance of the parallel and series configurations. The resistance of each bulb is calculated using R = V^2/P, leading to a total resistance of 360 ohms. The current through the circuit is found to be 0.33A, resulting in a voltage drop of 80V across the third bulb, which is noted as negative due to the loss of voltage. The calculations and reasoning provided guide towards completing the problem independently.
JonJon
Three 60 w 120 V bulbs are connected to a 120 V battery. 2 Bulbs are in parallel with each other in a smaller loop. The third is in series with the battery and the other loop.
find voltage difference across bulb three.
R= V^2/P
1/R_loop= 1/R_1
R=120^/60
1/R_total = 2/240 R_total= 120 +240 =360
I _total = V/R = 120/360
Start by finding the total circiut resistance.
You must have RT= RB+ RL
Were:
RB is the resistance of a single bulb and
RL is the resistance of the parallel pair of bulbs.
RL is :
\frac 1 {R_L} = \frac 1 {R_B} + \frac 1 {R_B}
So RL = .5 Rb
Now you should be able to complete the problem on your own.
I got V_3 is .33A * 240 = 80v but its -80v b/c its loosing right?
