Right angle triangle trigonometry
To determine the angle theta in a right triangle with a hypotenuse of 3 cm and an opposite side of 2 cm, the sine function is used, where sin(theta) equals the ratio of the opposite side to the hypotenuse. This leads to the equation sin(theta) = 2/3, which can be solved using the inverse sine function, yielding theta = 41.8 degrees. The discussion clarifies that the inverse sine function (sin^-1 or arcsin) is applicable for finding angles in trigonometric equations. It is emphasized that the sine function is specifically used in right triangles to relate the sides to the angles. Understanding when to apply these functions is crucial for solving trigonometric problems effectively.
aisha
The question says determine theta
I have a triangle with a hypotenuse of 3 cm
opposite the angle theta is 2cm length
and adjacent to that is unknown.
I don't know how to solve this question I don't remember what theta is lol or how to punch it in the calculator what do I do please help me refresh my mind. :confused:
You know that sin(\theta)=\frac{opp}{hyp}
therefore
sin(\theta)=\frac{2}{3}
sin^{-1}(\frac{2}{3})=\theta
\theta=41.8 degrees
ok so whenever I am solving for theta I use sin^-1 or do I use it whenever i am solving for any angle? what does sin^-1 do?
also how did u know to use sin ?
SOH CAH TOA. Depends on what #s you have
1.Yes,the equation:
\sin \theta=a is solved by applying on both sides of the equation the inverse function of "sin theta" (called \arcsin \theta) which would giveu the result.Note the degree of generality:no (right) tringles involved,justmathematical functions.
2.For any angle,for any argument of the function "sin",nit necessarily an angle.E.g.solve this equation for "x"
\sin(x^{2}-4x+3)=-0.12
"x"doesn't have the geomtrical interpretation of an angle,it's just "x",an arbitrary varible of a function f(x).
3.Solve for the angle? :rolleyes:
4.In a right triangle,the sine of an angle is defined as the ratio between the opposide side and the hypothenuse.Since u were given both the opposite side ("opposite the angle theta is 2cm length") and the hypothenuse ("hypotenuse of 3 cm"),it was natural to use "sin".
Daniel.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
