RLC circuit solved with Laplace transformation
5 replies · 4K views · last reply
MaxR2018
New poster has been reminded to use the Homework Help Template in the schoolwork forums
Hi, i need some help here. Can you help me?:sorry:
Here is the problem.
Exercise statement: The switch have been closed for a long time y is opened at t=0. Using Laplace's transtormation calculate V0(t) for t ≥ 0
Circuit schematic: 12V battery in series with a switch opened at t = 0, a 2 uF capacitor, a 200 ohm resistor and a 20 mH inductor, with vo(t) marked across the inductor. Below it, the solution vo(t) = 30x10^3 t e^-5000t + 12 e^-5000t [A].
This is what i made to solve it:
1) I know while the switch is closed, the current trough the circuit is i=12v/200, so i=60mA.
2) When the switch is opened at t=0, i use the voltages law of kirchoff:
12 = vc + vr + vl
12= (1/c)*(integrate of i dt from 0 to t) + vc(0) + iR + L(di/dt)
i know that vc(0) = 0
so : 12= (1/c)*(integrate of i dt from 0 to t) + iR + L(di/dt)
Then i used the laplace transformation:
12/s = I(s)/Sc + RI(S) + LSI(S) - LI(0)
And i know that LI(0)=60mA
so:
12/s = I(s)/Sc + RI(S) + LSI(S) - 60mA
Finally i calculate I(S) and then i obtain i(t) with the antitransformation of Laplace.
Then, with i(t) i calculate vt knowing that:
VL=L*(di/dt), but i obtain a diferent solution.
I obtain that V0(t) = -300000*e^(-5000t) + 12e^(-5000t)
What I am doing wrong??
I thing I am having a mistake with some signs.
Pd: Sorry for my bad english.
Thanks for reading me!
  • Circuit schematic: 12V battery in series with a switch opened at t = 0, a 2 uF capacitor, a 200 ohm resistor and a 20 mH inductor, with vo(t) marked across the inductor. Below it, the solution vo(t) = 30x10^3 t e^-5000t + 12 e^-5000t [A].
For I(s), I get:
$$I(s)=\frac{300}{(s+5000)^2}+\frac{0.06}{(s+5000)}$$
and, for v(s), I get $$v(s)=\frac{30000}{(s+5000)^2}+\frac{12}{(s+5000)}$$
Chestermiller said:
For I(s), I get:
One time you have I(s), you find V(s) with V(s) = LSI(S) - Li(0) ??
No. $$v(s)=RI(s)+LsI(s)-Li(0)$$You left out RI(s)
Ah, ok thanks! i thought the exercise was asking me for VL, but it really asking for the the voltage in R and L together! Thank you so much!
