Rock Group Performs in Bar: How Far Can You Hear?
  • Thread starter Thread starter stevenbhester
    Group Rock
The problem involves sound intensity levels produced by a rock group in a bar, specifically determining the distance at which the music is barely audible to a person with a normal threshold of hearing. The context includes sound intensity measured in decibels (dB) and the relationship between intensity and distance from the sound source.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss converting intensity levels from decibels to watts per meter squared and calculating the power of the sound source. There are attempts to derive the distance at which the sound is audible based on the given intensity level and threshold of hearing.
The discussion includes various attempts to solve the problem, with some participants questioning the validity of the calculated distance. There is acknowledgment of a possible typo in the distance value, and a participant suggests that the calculations may be correct despite the seemingly large result. An alternative approach is mentioned, indicating that multiple methods are being explored without a clear consensus.
Participants are operating under the assumption that sound absorption can be disregarded, which may influence the perceived realism of the calculated distances. There is also mention of a discrepancy with a website's feedback regarding the correctness of the calculations.
stevenbhester
A rock group is playing in a bar. Sound
emerging from the door spreads uniformly in
all directions. The intensity level of the music
is 116 dB at a distance of 5.77 m from the
door.
At what distance is the music just barely
of hearing? Disregard absorption.
Answer in units of m.
So,
Given-
I1(dB) (the intensity level 5.77 meters from the door)=116 dB
r1 (distance from door when intensity is 116 dB)= 5.77 m
Io (Intensity at threshold of hearing)= 1e-12
Unknown-
r2 (Radius at threshold of hearing)
P (power of sound source)
I1(w/m^2) (intensity 5.77 meters from door in watts/meters squared)
dB=10log(I/Io)
P=4*I*π*r^2
r=√(P/4πI)
First, I changed the given Intensity into W/m^2 instead of hertz.
dB=10log(I1/Io)
116=10log(I1/1e-12)
11.6=log(I1/1e-12)
10^11.6=I1/1e-12
(1e-12)(10^11.6)=I1
.3981071706=I1
So that's the Intensity at the spot from the door mentioned, so now I calculated the power source.
P=4*I1*π*r1^2
P=4*.3981071706*π*5.77^2
P=166.5564633
So, now that I had the power source, I calculated the radius needed to achieve threshold of hearing
r2=√(P/4πIo)
r2=√(166.5564633/4*π*1e-12)
r2=√(166.5564633/1.256637061e-11)
r2=√1.325414222e13
r2=3640623.878
Doesn't seem right... 3.6 million miles seems overkill.
I think you mean 3.6 million meters. :wink:
Oops, typo... question still stands though :)
Could you help with my question though please?
It may seem like a lot, I agree. But 116 dB is pretty loud, and we are ignoring absorption and all that. :cool: I mean it's really only 3640 km. That's just peanuts compared to the size of, say, the galaxy.
Seriously though, I don't see any mistakes with your math. There is a much easier way to solve this problem, but the answer comes out the same as yours.
Edit:
Okay, I'll bite with the easier solution. After all, you did already get the answer.
Note that I'll use 0 dB use the human threshold of hearing. In other words,
[tex]0 \ \textbox{dB} = 10 \ \textbox{log} \left( \frac{I_0}{I_0} \right)[/tex]
Also take note that
[tex]I \propto \frac{1}{r^2}[/tex]
So construct the problem as you have already done,
[tex]116 \ dB = 10 \ \textbox{log} \left( \frac{I_1}{I_0} \right)[/tex]
Now note that at some distance r2 we're going to end up with an intensity I0
So we can say,
[tex]I_0 \propto \frac{1}{(r_2)^2}[/tex]
and
[tex]I_1 \propto \frac{1}{(r_1)^2} = \frac{1}{(5.77 m)^2}[/tex]
So make your appropriate substitutions, and note that
[tex]10 \ log \left( x^2 \right) = 20 \ log \left( x \right)[/tex]
Solve for r2.
Thanks, I guess the website is at fault. It maintains that I'm wrong. :(
11K
16K
