How can the motion of point A be determined in this system?
  • Thread starter Thread starter Vibhor
    Rod Strings
The discussion revolves around determining the motion of point A in a system involving a rod and tension. When the string connecting point B is burnt, the forces acting on the rod lead to a vertical acceleration of its center of mass (COM) and a clockwise rotation. The acceleration of point A is debated, with some asserting it must be horizontal to the right due to the vertical tension, while others argue it could also have vertical components. The conversation includes mathematical considerations of forces, torques, and kinematic relationships to clarify the motion at the moment just after the string is burnt. Ultimately, the complexity of the problem is acknowledged, with participants expressing frustration over the lack of progress in reaching a consensus.
Vibhor
When string joining B is burnt , the forces acting on the rod are its weight , and tension in the left string ,both being vertical ,the acceleration of its COM would be vertical . Hence option A is correct .
Now how should particle at A move ?
Please help me with the problem .
Thanks
Why don't you try it out?
http://www.buero-netshop.de/shop/images/products/main/q-connect-lineal-20cm-kunststoff-transparent.jpg
Hang it ( in the hole, using sewing thread ) and hold it ( at 20cm ). Let it go.
Watch what happens.
Likes berkeman
Watch what happens.
This is not a valid test. Yes, over time there will be a motion at A, and the motion will initially be horizontal. But this does not prove that instantaneously there is a horizontal acceleration at A. It could be that the first and second derivatives of x are zero, but the third is positive.
If x is the position, I thought that the acceleration ( which is the question ) is the second derivative: d2x/dt2.
Quite so, but my point is that at t=0 it may be that both ##\dot x## and ##\ddot x## are zero. The first nonzero derivative will surely be positive, but it might be third derivative.
haruspex said:
my point is that at t=0 it may be that both x˙\dot x and x¨\ddot x are zero
At t = 0 the acceleration of A will be positive to the right because the thread at A is vertical, thus not yielding any horizontal force ( B is burned ). The rod will begin to rotate clockwise, and the center of the rod will be kept in the same horizontal position. Thus A must accelerate to the right, and B must accelerate to the left.
We are speaking of the acceleration at t = 0+ ?
This is a possibility . But why must A accelerate to the right only . It can accelerate upwards and B can accelerate downwards such the COM of the rod accelerates downwards ?
Can this be proven mathematically ?
Can you show us your FBD for t=0+? The sum of torques and forces are non-zero for t=0+. That should help you start to answer this question...
Tension acts vertically upwards and weight acts vertically downwards on the rod .
Agreed . But how does that show that particle at A accelerates horizontally ?
You didn't do what I asked. Please post a FBD -- that will answer your questions...
Please see the attached picture .
So given that FBD, what is the sum of forces and sum of moments on the bar?
Please understand that merely having a net force acting and a net torque around the COM doesn't prove that the particle at A accelerates horizontally .
Consider a particle moving in one dimension according to x=ct3. What is its acceleration at t=0?
However, rereading the question, I see that it seems to be asking about the acceleration at some time marginally greater than zero. This strikes me as strange since offering the two options as either horizontal or none would make more sense at t=0. Moreover, as soon as you allow t>0 there will be a vertically upward acceleration too, making neither answer correct.
Anyway, it is possible to prove there is a nonzero horizontal acceleration even at t=0, but it takes a little more analysis than the observational approach you posted.
The problem statement says:
So, what is meant by: "just after this"?
Well, the acceleration = d2x/dt2. Now, some physicists think that the time itself is quantified into amounts of ≈ 1E-49s. So if we write:
v(t) = dx(t)/dt
we must add: "assuming dt >> 1E-49s". Otherwise the equation doesn't make sense. So I think that the author by "just after this" means something like "within the next μs".
Should I consider what will happen within the next 1E-52s, I would get crazy. I don't want to get into that discussion due to quantified time.
I don't understand your conclusion here? As for the vertical accelerations Bacc ≈ g , centeracc ≈ ½g , Aacc = 0.
If there is a net torque around the COM, what does that tell you about the angular acceleration around the center of mass? How is the velocity of particle A related kinematically to the velocity of the center of mass and the angular velocity (vectorially)?
Hello Sir ,
Thanks for replying
There is a net angular acceleration around the center of mass = Net torque / MI
##\vec{v}_A = \vec{\omega} \times \vec{r} + \vec{v}_{CM}##
Actually, this is close, but is not quite correct. The correct relationship is:
$$\vec{v}_A = \omega r\vec{i}_θ + \vec{v}_{CM}$$
where ##\vec{i}_θ## is a unit vector in the circumferential (tangential direction). The time derivative of this is the acceleration of particle A. If θ is the angle that the unit vector in the tangential direction makes with the positive x axis, how is the unit vector in the tangential direction related to the unit vectors in the x and y directions?
Chet
##\vec{i}_θ = cosθ\hat{i}+sinθ\hat{j}##
OK. Now substitute that into the equation for the velocity of particle A and take the time derivative. (You can just leave the time derivative of the center of mass in dv/dt form). What do you get?
Chet
##\vec{v}_A = \omega rcosθ\hat{i} + \omega r sinθ\hat{j} + \vec{v}_{CM}##
##\vec{a}_A = r[\ddot{\theta}cos\theta - {\dot{\theta}}^2sin\theta]\hat{i} + r[\ddot{\theta}sin\theta + {\dot{\theta}}^2cos\theta]\hat{j} + \dfrac{d\vec{v}_{CM}}{dt}##
What is the value of the angular velocity of the rod at time zero? Substitute this value into your equation for a, and call the angular acceleration α. So what is the acceleration of particle A at time zero in terms of these parameters? What is the horizontal component?
Chet
To a first approximation, the acceleration vector at A at a small time t after release is (a, bt2) for nonzero constants a, b.
Specifically, if the radius of inertia of the rod is k, the horizontal distance between A and the mass centre is w, the angle of the rod to the horizontal is theta, and the length of the string at A is r, then ##a=\frac{w^2}{w^2+k^2}g\tan(\theta)##, ##b=\frac{a^2t^2}r##. (The vertical acceleration is, of course, centripetal.)
It follows that at t=0 there is only a nonzero horizontal acceleration, but that at any later time there is both horizontal and vertical acceleration.
##\vec{a}_A = rcos\theta\alpha\hat{i} + rsin\theta\alpha\hat{j} + \dfrac{d\vec{v}_{CM}}{dt}##
##\vec{a}_{A,x} = rcos\theta\alpha##
Good. Nice job.
But how does that tell us that net acceleration of the particle is in horizontal direction at t=0 :rolleyes: ?
We have to find the direction of net acceleration , not its magnitude .
Opps. I lost track of the problem statement. We need to address the vertical component of A's acceleration.
What is the vertical acceleration component of A at time zero?
What is the tension in the left wire at time zero?
What is the vertical acceleration of the center of mass at time zero?
If this is substituted into the equation for the vertical acceleration, what do you get?
(We're not done yet)
Chet
PLEASE DISREGARD THIS POST. IT IS BOGUS. THE OP HAD THE ANALYSIS CORRECT IN THE FIRST PLACE. SORRY FOR ANY CONFUSION I MAY HAVE CAUSED. SENIOR MOMENT.
BOTH THE OP's EQUATIONS IN POST # 24 ARE CORRECT, PROVIDED α IS THE ANGULAR ACCELERATION IN THE CLOCKWISE DIRECTION.
Actually, your equation for ##\vec{i}_θ## in post #19 is correct for θ being equal to the angle the rod makes with the negative x-axis (with ##\vec{i}_θ## pointing clockwise), rather than the angle that ##\vec{i}_θ## makes with the positive x axis. Your subsequent equations are correct for this framework. So, we can continue from where we left off.
Chet
Which post are you referring to , post#27 or post#28 ?
What should be the next step after post#24 ?
Post #28.
See post #27. By the way, this is likely to get a little tricky. I don't think the person who conceived of this problem realized how complicated it is.
Chet
  • #31
Chet
I think , I should leave this problem as it has already taken up so much of my time . I had been thinking about this problem for past few days .After some real hard thinking I decided to post it here . But after so many posts , there hasn't been any progress .
Thank you Sir for your valuable time . I really appreciate your help .
  • #32
I have one more thing to say before stopping. Since the horizontal velocity of A is zero at time zero, then, as reckoned along a line from the connection point at the ceiling to point A, the centripetal term in the expression for radial acceleration of A toward the connection point at the ceiling is zero. And since the wire is presumed inextensible, the second derivative of the distance between the connection point at the ceiling and point A is also zero. The sum of these two terms is equal to the vertical component of the acceleration of point A at time zero. So, at time zero, the vertical component of acceleration of point A is equal to zero.
Chet
Likes Vibhor
  • #33
@Vibhor, @Chestermiller: you seem to have been at pains to show that there is no vertical acceleration at t=0. The question does not offer nonzero vertical acceleration as an option anyway, so I would think the question setter accepts it is obvious there is none. There cannot be a vertically downward acceleration, and the tension in the string will only be sufficient to prevent that, and there is no other force to create an upward acceleration.
Thus, I read the question as purely a matter of deciding whether there is a nonzero horizontal acceleration at t=0. This is not as completely trivial as two other posters on the thread thought, but it can be settled with a fairly straightforward argument, making the question and solution satisfying.
However, this reading is belied by the wording of the question. It asks about a short time after the B thread combusts, not t=0. Not only does that make it far too obvious that there will be a horizontal acceleration, there will also be a vertical acceleration, making the offered answers both incorrect. Therefore I believe the wording does not describe the intended problem. It should be asking about t=0. But that's just an opinion.
  • #34
The fourth option in the problem statement says that "The acceleration of point A is horizontal." To me this means that you need to show that the horizontal acceleration is non-zero, and the vertical acceleration is zero.
In post #32, I believe I presented a very convincing proof that the vertical acceleration of A is zero immediately after the cord is cut.
Vibhor and I analyzed the problem mathematically, and let the math do the work for us to show that the horizontal acceleration is nonzero.
It's pretty clear to me (at least in my personal judgement) that they meant for you to assume that at time t = 0+, all the velocities are zero.
Likes Vibhor
  • #35
Ok, thanks - I must have not followed your exchanges closely enough.
  • #36
The answers become clear when we write the equations for the motion of the CM and point A in general. In this case, the string encloses the angle φ with the vertical while the beam encloses angle θ. Let be the length of the beam 2L, and r the length of the string.
xA=rsin(φ), yA=rcos(φ)
##\ddot x_A=−rsin(φ){\dot φ}^2+rcos(φ)\ddot φ##, ##\ddot y_A=−rcos(φ){\dot φ}^2−rsin(φ)\ddot φ##
At t=0+, φ=0, ##\dot φ=0##, so ##\ddot x_A=r\ddot φ##, ##\ddot y_A=0##, point A accelerates in horizontal direction.
##X_{CM}=L\sin(θ)+rsin(φ)##, ##Y_{CM}=L\cos(θ)+r\cos(φ)##
##\ddot X_{CM}=-L\sin(θ){\dot θ}^2+L\cos(θ)\ddotθ-r\sin(φ){\dot φ}^2+r\cos(φ)\ddotφ##
##\ddot Y_{CM}=-L\cos(θ){\dot θ}^2-L\sin(θ)\ddot θ-r\cos(φ){\dot φ}^2-r\sin(φ)\ddotφ##
At t=0, ##\ddot X_{CM}=L\cos(θ)\ddot θ+r\ddot φ##, ##\ddot Y_{CM}=-L\cos(θ)\ddot θ##
For the translation of the CM:
##m\ddot X_{CM}=-T\sin (φ)##
##m\ddot Y_{CM}=-T\cos (φ)+mg##
The torque equation with respect to the CM:
##TLsin(θ-φ)=-\frac{1}{3}mL^2 \ddot θ##.
At t=0:
##\ddot X_{CM}=0##, ##\ddot Y_{CM}=-T+mg##
##TLsin(θ)=-\frac{1}{3}mL^2 \ddot θ##.
T can be eliminated, ##\ddot θ##and ##\ddot φ## determined for t=0.
Likes Vibhor
