Rotating Cylinder placed on rough surface
A rotating cylinder placed on a rough surface experiences energy loss due to sliding friction before it rolls smoothly. Initially, the cylinder has only rotational kinetic energy, but friction causes a transition that affects both its linear and rotational motion. The torque from friction decreases the cylinder's rotation while accelerating its center of mass. The final state requires the velocity of the center of mass to equal the linear velocity of the rim. Energy is not conserved during this process, necessitating a force-level analysis rather than purely energy methods.
thepopasmurf
A cylinder is rotating about its axis and is placed on a rough surface. Find out what fraction of the initial Kinetic energy is lost due to sliding friction before the cylinder rolls smoothly.
1/2 m v^{2} + 1/2 I \omega ^{2} = KE
rough surface -> v=\omegar
moment of inertia of cylinder is 1/2mr^{2}
I don't really have an attempt because I am not convinced why there should be energy lost due to friction. If I weren't told that I would just equate the initial KE and the final KE and find the relationship between \omega_{i} and \omega_{f}
The answer should be 2/3
Well, you're letting an object move on rough surface.
Surely you see that if you throw your slipper on the floor, it would stop moving after it traveled for some time.
Well, the question concerns the transition between rotating in free space and rotating on a rough surface. Apparently there is sliding friction when this happens. I am assuming that in the final state of the system, the cylinder is rolling smoothly with constant velocity.
Originally the cylinder had only rotational kinetic energy. Placing it on the rough surface, there is sliding friction acting on it. This force has torque: the torque decreases rotation. The force accelerates the linear motion of the centre of mass. When the cylinder rolls, the velocity of the CM is equal to the linear velocity of the rim.
Write the equation of motion both for the translation and for the rotation and find the time when vCM=rω. Then calculate the sum of the translational and rotational KE.
ehild
Thanks, I didn't actually consider the problem on a force level, I assumed it could be done via energy methods.
The energy is not conserved. How do you apply energy methods?
ehild
