Rotating Wedge & Rise of Mass: Speed Calculation
The discussion focuses on calculating the speed of a mass rising on a frictionless rotating wedge, where the relationship is established as v = sqrt(gLsinθ). Participants clarify that the radius of the circular path (r) is equal to the distance (L) the mass rises. The gravitational force component acting down the incline is expressed as mg sin θ, which is crucial for deriving the equations of motion. A free body diagram is recommended for better understanding the forces involved. Overall, the conversation emphasizes the importance of resolving forces and understanding the relationship between the wedge's geometry and the mass's motion.
hauthuong
the sloping side is frictionless, it is spun at constant speed by rotating the wedge. show that when a mass rises up the wedge a distance L, the speed of the mass is v=sqr(gLsin0)
I got Fx=m(v^2/r) = mgsin0
v^2=g*sin0*r
can I say r=L ?
I got stuck, could you give me some hints thank you
Hint: Gravity is the centirpetal force because it is pulling the block towards the center.
What is your specific problem with this? Tried resolving normal reaction in the right direction? Do you know what the radius of the circular path is?
Yes r will be L.
mgsin\theta = m \frac{v^2}{l}
\sqrt{lgsin\theta} = v
thank you, however, i do not quite understand why r=l. Could you please explain
Where you get the equation m(v^2/r)=mgsin0. I have search for many reference book but can't find this equation .Can you tell me ?
Cyclovenom said:
Yes r will be L.
In my analysis, I resolve the normal reaction in the horizontal and vertical direction. This gives,
N\cos\theta = mg
N\sin\theta = \frac{mv^2}{l\cos\theta}
I divide equation 2 by equation 1 to get
v^2 = gl\sin\theta
Cheers
Vivek
mg sin theta is the component of the weight acting down the incline (resolve mg in two directions one parallel and the other perpendicular to the plane). Drawing a well labeled freebody diagram might help.
Yes Maverick, that's a correct analysys for the way your coordinate system was put, although i prefer your way than mine, because it is using the vertical coordinate system (most used in Circular Motion) rather than the inclined one.
