Understanding Homework Equation: Lφ=rθ
  • Thread starter Suraj M
  • Tags
    Homework
In summary: The first formula in the original post is the same as the one in the link Nidum providedExcept the change in symbolsThat theta isn't the one I used here in post #9I'm sorry for thatI took theta to be the angle of twist at the junction And then I thought that the angle would be inversely proportional to the polar moment of inertia, which is actually a function of ## r^4##So I equated thatAs I've shown I don't know if it's right I just used some basic logic to link the difference in the angle at one end and the resulting twist angle at the other end to radius
Suraj M
39
## L\phi = r \theta##
Firstly I'm not sure what ##\phi## and ##\theta## mean in the equation,
If I were to attempt I'd want to equate the lengths
$$ \frac{2r\theta_1}{\phi} = \frac{r\theta_2}{\phi} $$
I felt ##\theta_2## is zero and ##\theta_1 = \phi in the question##
Definitely wrong
Could you help?
The cylinders are made of the same material, they are of the same length and the torque is constant vs. the whole length - their torsional stiffness and the angle only depend on the geometry.
First of all: Can you eliminate two answers without any calculations?
Secondly: Do you know what geometrical dependent property defines the torsional stiffness of a body?
C and D are gone since they're more than the original angle
Geometrical dependent property?[emoji20][emoji17] sorry but no
Where can o find out more
Our teacher didn't even teach us this topic but there are questions on it [emoji53]
The torsional stiffness depends on the geometry of the body - it seems to be quite obvious, that the cylinder with the larger diameter is more stiff, than the cylinder with the smaller diameter. But how much? You need the look up the area moment of inertia. This property is a measure for the resistance of the body against deformation. In your case, a body applied to a torque, you need to find out the polar area moment of inertia of a rigid cylinder.
Comparing the polar area moments of inertia of two cylinders with r and 2⋅r (by dividing one by the other) will give the answer to your question.
EDIT: Your thougt regarding answers C and D is correct.
If you work out what the a and b choices translate into in terms the ratio between the twist in one cylinder and the twist in the other, it's kind of obvious which one to choose, even without understanding any of the theory.
Nidum said:
Here is a simple tutorial on torsion of shafts which will help you understand the background theory to your problem :
http://www.slideshare.net/osmak93/mm2105a
I'm really sorry but I didn't quite follow after they derived the basic formula relating length radius and angle
How could I decide between A and B without solving?
Oh wait
Is it like this?
$$ \frac{\phi - \theta}{\theta-0} = (\frac{r}{2r})^4 $$??
Then I get option B
Right?
Suraj M said:
Oh wait
Is it like this?
Then I get option B
Right?
Where did you get the formula you use (and you showed in your first post) from? And what does θ stand for in this equation? It doesn't seem very common to me, I would try to solve the task in a different way - but I don't have to deal with strength of materials on a regular basis, so maybe my thought is not correct.
Suraj M said:
Oh wait
Is it like this?
Then I get option B
Right?
Yes.
I'm sorry for that
So I equated that
As I've shown
Could you direct me to a more refined way?
haruspex said:
Yes.
And this-?
Suraj M said:
And this-?
Having got it down to a choice of A 15:1, and B 16:1, and knowing the radius ratio is 2:1, the twist ratio of 16:1 looks far more likely.
Ah! Okey
Thanks a ton EVERYONE
Really appreciate it [emoji4]
What is the homework equation Lφ=rθ?
The homework equation Lφ=rθ is a mathematical formula used to solve problems related to rotational motion. It relates the linear displacement (L) to the angular displacement (φ) and the radius (r) to the angle (θ).
How is the homework equation Lφ=rθ derived?
The homework equation Lφ=rθ is derived from the definition of angular velocity, which is the rate of change of angular displacement over time. By rearranging the equation, we can solve for L in terms of φ and r.
What are the units for Lφ=rθ?
The units for Lφ=rθ will vary depending on the units used for the different variables. For example, if L is measured in meters and r is measured in meters, then the units for φ will be radians and the units for θ will be radians. If different units are used, the equation can be converted accordingly.
How is the homework equation Lφ=rθ used in physics?
The homework equation Lφ=rθ is used in physics to solve problems related to rotational motion, such as calculating the linear displacement of an object given its angular displacement and radius. It is also used in other areas of science, such as engineering and astronomy, where rotational motion is relevant.
Are there any limitations to the homework equation Lφ=rθ?
While the homework equation Lφ=rθ is a useful tool for solving problems related to rotational motion, it does have some limitations. It assumes that the object is moving in a perfect circular path and that the rotational motion is constant. Additionally, it does not take into account other factors such as friction or air resistance, which may affect the accuracy of the calculated values.
