Shell Method Problem: Solve x=y^(2), x=4 About the X-Axis
  • Thread starter Thread starter hvidales
    Method Shell
The discussion revolves around the shell method for calculating the volume of a solid of revolution formed by rotating the region bounded by the curves x = y² and x = 4 about the x-axis. Participants are exploring the setup and limits of integration for this method.
  • Mixed
  • One participant attempts to set up the integral for the shell method but expresses confusion over the limits and the resulting value. Others question the limits of integration in a related problem involving different curves and provide insights into the reasoning behind those limits.
The discussion is ongoing, with participants exploring different interpretations of the problem setup and limits of integration. Some guidance has been offered regarding the reasoning behind the limits in a similar example, but no consensus has been reached on the original problem.
Participants are navigating the complexities of applying the shell method versus the disk method, and there are indications of confusion regarding the limits of integration based on the geometry of the regions involved.
hvidales
x=y^(2), x=4, about the x axis.
2pi* integral from a to b of radius*height of function*thickness
I have 2pi* integral from -2 to 2 of y*(4-y^(2)) dy but that does not make any sense. Answer comes out to be 0. The real answer is 8pi. I know how to do this with the disk method just not the shell method. Thank for the help!
hi hvidales! :smile:
hvidales said:
… integral from -2 to 2 …
noooo :wink:
I see and thanks. However, how come for this problem: y=x^(2), y=2-x^(2), about x=1 the limits are from -1 to 1 ?
you mean x goes from -1 to 1?
that's because the body in that case goes from x = -1 to x = 3 (the reflection about x = 1)
in your first example the body went from y = -2 to y = 2
in each case, you're taking half (because each single cylindrical shell is in both halves) :wink:
Thank you!
