Is the Velocity Equation for SHM Correctly Derived Without Calculus?
The discussion revolves around the derivation of the velocity equation for simple harmonic motion (SHM) without using calculus. The initial equation provided is v = -wx0cos(wt), where v0 is the maximum velocity and ω is the angular frequency. Clarification is sought on how to express velocity when displacement is at its maximum and how the sine function applies at different time instances. It is noted that if t=0 when the particle is at equilibrium, the displacement equation becomes x = A sin(ωt), leading to the velocity equation v = Aw cos(ωt). The conversation emphasizes understanding the relationship between displacement, velocity, and the role of sine and cosine in SHM.
ProPM
Hi :smile:
I am a bit lost with the equations for velocity:
I don't know Calculus yet, so my teacher just gave me the equation:
-wx0cos(wt) (w being omega)
He then said: v0 = wx0
and therefore, concluded: -v0cos(wt)
and then for when the displacement is maximum at time = 0: v0cos(wt)
Is this correct? I mean, I am obviously not doubting him but I am a bit confused plus my notes were not very organized on this day...
Thanks in advance
when t =0, ωt = 0 and cos(ωt) = 1
So vo = -xo*ω
So the equation would be:
v0cos(wt)
and for sin, how would it work?
The sign and the function sin or cos depends on the instant you are taking t=0. If t is taken zero when the particle is at the equilibrium position (x=0) than the equation for displacement will be x= A sin wt and that for velocity will be v = Aw cos wt
thus at extreme position wt = 90 deg, gives x = A and v = 0.
(A is amplitude and Aw = Vo, the maximum velocity)
