Simple Harmonic Motion- Phase Shift Help
A 590.0 g mass oscillating with an amplitude of 11.4 cm on a spring with a spring constant of 27.7 N/m is analyzed for its phase shift. The angular frequency was calculated as 6.85 rad/s, leading to the equation x(t)=0.114cos(6.85t + phi). The initial position at t=0 was used to find cos(phi), resulting in a value that led to confusion regarding the phase shift calculation. After some back and forth, the correct phase shift was determined to be -1.29 rad, clarifying the misunderstanding about the addition of angles. The discussion emphasizes the importance of correctly interpreting the cosine function and its relation to phase shifts in simple harmonic motion.
Brian M
A 590.0 g mass oscillates with an amplitude of 11.4 cm on a spring whose spring constant is 27.7 N/m. At t=0.00 s the mass is 3.14 cm to the right of the equilibrium position and moving to the right.
x(t)=Acos(Wt + phi)
I already found the angular frequency(W) to be 6.85 rad/s to give the equation
Then I plugged in the position and at t=o to give
0.0314=0.114cos(phi)
cos(phi)=(0.0314/0.114)
cos^-1= 1.29 rad
I took that number and added 3pi/2 to give a phase shift of 6.00 rad. Which is wrong, I'm not sure why that wouldn't be the correct answer. Thanks for the help.
cos^-1= 1.29 rad
Why did you add 3pi/2? cos(3pi/2+phi) is not 0.0314/0.114.
ehild
My mistake, I left out a step. I thought the phase shift was greater than 1.29 rad, so i took the angle between that and 1/2pi (0.28 rad). I added that number to 3pi/2 for a phase shift of 4.99 rad, which is still wrong.
Draw the unit circle and see the cosine of which angles are equal.
Are not they phi and 2pi-phi?
ehild
Yes they are, and 2pi-phi = 4.99 which I already tried. I'm stumped here
Have you tried really? If we take the direction "to the right" positive phi =4.991 or (-1.292) rad. No need to add anything.
ehild
Yeah the correct answer was -1.29 rad. Thanks for the help
