Simple Harmonic Motion - rearranging equation
The discussion focuses on rearranging the equation for frequency in simple harmonic motion, f = (1/2π)√(k/m). A participant attempts to isolate variables, specifically expressing k in terms of f and m. The conversation highlights the importance of understanding the intention behind rearranging the equation, such as achieving a linear relationship between variables. Ultimately, the participant confirms they successfully figured out how to rearrange the equation to find k. The thread emphasizes the relevance of context in mathematical manipulation.
Jess_18033152
How to rearrange following equation?
f = (1/2pi) square root of (k/m)
(f^2 x m)/ (1/2pi)^2
Is this how i would do it?
Depends on what your intention is :smile:
Do you vary something and measure something else, and want to obtain a linear relationship ?
Thanks, I wanted to find k but worked out how to rearrange it :)
