Simple Harmonic Motion - Vertical Spring
meep82817
A block with mass m =7 kg is hung from a vertical spring. When the mass hangs in equilibrium, the spring stretches x = 0.23 m. While at this equilibrium position, the mass is then given an initial push downward at v = 4.7 m/s. The block oscillates on the spring without friction.
2. Questions
After t = 0.36 s what is the speed of the block?
What is the magnitude of the maximum acceleration of the block?
At t = 0.36 s what is the magnitude of the net force on the block?
3. Equations and the attempt at a solution
I calculated k by m*g/x
w by sqrt(k/m)
A by V*sqrt(m/k) (based on energy)
For speed, I used v(t) = -w*A*sin(w*t)
For acceleration, I used amax = wˆ2*A
For force, I used F(t) = k*A*sin(w*t)
I get the feeling my mistake is on my calculation for A. Help please? I've been working on this for a while and am starting to get frustrated.
Can you write out what all your parameters are instead of just denoting them by w, A etc. Would make it so much easier to see what you do.
Sure.
- k is spring constant
- A is amplitude
- w is angular frequency (rad/s)
What is large V here?
Oh. My bad. I used the velocity of 4.7 m/s that the statement provides.
The amplitude of the oscillation gives the total energy of the spring through the use of potential energy. So E = 1/2 A²k or A = sqrt(2E/k) = sqrt(mV²/k) = V sqrt(m/k) so is the same as yours. Looking through what you got, you got your speed wrong, otherwise it looks good.
Thread 'Need help understanding this figure on energy levels'
This figure is from "Introduction to Quantum Mechanics" by Griffiths (3rd edition). It is available to download. It is from page 142. I am hoping the usual people on this site will give me a hand understanding what is going on in the figure. After the equation (4.50) it says "It is customary to introduce the principal quantum number, ##n##, which simply orders the allowed energies, starting with 1 for the ground state. (see the figure)" I still don't understand the figure :( Here is...
Thread 'Understanding how to "tack on" the time wiggle factor'
The last problem I posted on QM made it into advanced homework help, that is why I am putting it here. I am sorry for any hassle imposed on the moderators by myself. Part (a) is quite easy. We get $$\sigma_1 = 2\lambda, \mathbf{v}_1 = \begin{pmatrix} 0 \\ 0 \\ 1 \end{pmatrix} \sigma_2 = \lambda, \mathbf{v}_2 = \begin{pmatrix} 1/\sqrt{2} \\ 1/\sqrt{2} \\ 0 \end{pmatrix} \sigma_3 = -\lambda, \mathbf{v}_3 = \begin{pmatrix} 1/\sqrt{2} \\ -1/\sqrt{2} \\ 0 \end{pmatrix} $$ There are two ways...
