Heat Pipe Questions: Understanding Two Phase Cooling and Pressure Changes
  • Thread starter Thread starter Yarbles
    Heat Pipe
In a sealed, vertical heat pipe half-filled with water, applying heat to the bottom half while maintaining the top at 120°C will not keep the inner surface of the bottom half at 120°C if it remains submerged. Once the water reaches 120°C, the pressure will increase with additional heat input, as the system must accommodate the vaporization of water. Lowering the pressure inside the pipe before heating can enhance the efficiency of heat transfer and allow for vaporization at lower temperatures. The presence of air in the pipe can impede heat transfer and create pressure variations, complicating the thermal dynamics. Understanding these factors is crucial for optimizing two-phase cooling systems.
Yarbles
Hi,
To help me understand two phase cooling etc. I have some simplified heat pipe questions:
If a sealed, vertical pipe, half filled with water has heat applied to its bottom half and the top half is held at 120C, is it safe to say that the inner surface of the bottom half of the pipe will also stay at 120C (assuming it stays under water)?
Once the water reaches 120C, will the pressure remain the same regardless of how much heat is applied?
Finally, what would be the effect of lowering the pressure inside the pipe before any heat is applied (as with real heat pipes)?
Thanks,
Y.
Very small part of water evaporate up to the saturation vapour pressure to alter the exhaust temperature to 120 C.
At that temperature, about 20% of heat is needed to raise water one unit and 80% is needed to transition from liquid to vapor. Other factors include whether air is in the pipe, insulation, whether heat is transferred along the pipe. In general, to have a steady state solution, there will be a temperature variation through the length of the pipe. In the ideal case, with no heart transfer along the pipe, there could exist a steady state with 120 C constant in the vessel, heart in equals heat out. If heat inb is increased, temp would rise unless heat out is also increased.
Im a little confused by most of that but 'air in the pipe' got me thinking.
What effect would air have in my simplified pipe above?
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
