Help with Simple Pendulum Physics Homework
The discussion revolves around solving a physics homework problem related to a simple pendulum. The student has derived the angle of the pendulum as a function of time but seeks assistance in determining the period and amplitude based on initial conditions A and B. Participants clarify that the period of oscillation can be found using the angular frequency, which is derived from the gravitational constant and the length of the pendulum. Additionally, they explain that the tension in the string balances the weight of the pendulum mass, with the vertical component of tension being crucial. The conversation emphasizes the importance of initial conditions in determining the unique solution to the pendulum's motion.
juef
Hey all,
I'm a math students, and I've got physics homeworks to do, and... I need some help :smile:
To make it short, I solved the approximation of the differential equation of the angle of a pendulum in function of time, and I got this:
\theta(t)=\frac{B\sqrt{L}sin(\frac{t\sqrt{g}}{\sqrt{L}})}{\sqrt{g}}+Acos(\frac{t\sqrt{g}}{\sqrt{L}})
Up to now it's pretty ok, but now I'm asked to find the period (is that word right?) and amplitude of this solution in function of A and B. Since I have absolutely no idea what these could be, I'm now asking you :biggrin:
Oh, and a few more little things...
How can I find the tension of the string in such a pendulum?
What do x''(t) and y''(t) represent in this situation? The horizontal and vertical accelerations perhaps?
Thank you very much!
juef said:
Hey all,
I am not sure how you got this. The differential equation is:
\frac{d^2\theta}{dt^2} = - \frac{g}{L}\theta
The general solution is:
\theta(t) = Asin(\sqrt{\frac{g}{L}t})
The vertical compontent of the tension balances the weight of the pendulum mass. So Tcos\theta = mg
AM
Not really,Andrew,it's,in the general case a combination of sine & cosine (small angles)...Initial conditions which make up the Cauchy problem (together with the ODE) decide the unique solution.
It's a custom to depict the angular frequency
\omega=:\sqrt{\frac{g}{l}}
The period of oscillation is triavial to find.
Daniel.
Thank you both for your help! Yeah, the solution I got is different because there is possibly a value greater than zero for \theta'. My initial conditions are: \theta(0)=A and \theta'(0)=B. I am asked to find the amplitude and period of oscillation in function of A and B...
