What Is the Pressure Inside a Water Cannon Shooting at 25m/s?
  • Thread starter Thread starter ChickysPusss
The discussion centers on calculating the pressure inside a water cannon that shoots water at 25 m/s. Using Bernoulli's principle, the user calculated the height required for this velocity to be approximately 31 meters, leading to a pressure of 303,800 Pa. However, the textbook answer is 4.125 x 10^5 Pa absolute, prompting questions about the inclusion of atmospheric pressure in the calculations. It was clarified that the discrepancy arises from not accounting for atmospheric pressure, which adds approximately 100,000 Pa to the calculated gauge pressure. The conversation emphasizes the importance of considering absolute pressure in fluid dynamics problems.
ChickysPusss
Water is coming out of a water cannon at 25m/s, what is the pressure inside the cannon?
Bernoulli's (modifiedd): v = √(2gh) -> h = v^2/2g
Prssure(liquid) : P = ρgh
Well, I wasn't too sure how a water cannon works, so I "made one" that is just a giant vat with a lot of water, and a hole at the bottom.
I figured that for the water to come out at 25m/s, the height would have to be ~31m.
h = (25^2)/2g
So then I said, Pressure must be equal to ρgh, which is 1000 * 9.8 * 31m = 303,800Pa
But the answer the book gives says its "4.125 x 10^5 Pa absolute."
Any idea why my solution is incorrect?
Absolute pressure? Did You take into consideration atmospheric pressure?
Oh jeeze, I guess that would give me the ~100000 Pascals I need for the answer, thanks!
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
