Simple Work Done by Force Problem
The problem involves calculating the work done by a force on a particle using the dot product method. The force vector is given as \vec F = (-4.0\hat\imath - 6.0\hat\jmath) N and the displacement vector as \Delta\vec{r} = (-3.0\hat\imath + 2.0\hat\jmath) m. The correct approach is to compute the dot product directly, resulting in a scalar value rather than creating a new vector. The initial calculation led to confusion, but the correct final answer for the work done is zero. The discussion emphasizes the importance of understanding the nature of the dot product in vector calculations.
tangibleLime
How much work is done by the force \vec F = (-4.0\hat\imath-6.0\hat\jmath)\;{\rm N} on a particle that moves through displacement \Delta\vec{r}=(-3.0\hat\imath+2.0\hat\jmath)\;{\rm m}?
A_{x}B_{x} + A_{y}B_{y}
I decided to use the component form of the dot product method for this problem. (Or is the component form an alternative to the dot product?) Anyways, I set F as A and R as B, resulting in the following:
F_{x}r_{x} + F_{y}r_{y}
\vec F = <-4, -6>
\vec r = <-3, 2>
-4(-3) + (-6)(2)
\vec C = <12,-12>
Then I took the square root of the sum of the sqaures:
\sqrt{12^{2}+(-12)^{2}}
\sqrt{288} \approx 17
My answer of 17 was marked incorrect. Where did I go wrong? Any input is greatly appreciated.
I just realized that I must have made some major mistake. I just kind of "created" vector C out of nowhere. Any direction on this problem would be great.
EDIT: Nevermind, I figured out my error. Instead of creating vector C, I should have just stopped there, added 12 and -12, and got the correct answer of zero. Huzzah!
The dot product is not a vector! It is scalar.
ehild
