Simplest way to approximate sqrt of complex numbers
To approximate the square root of complex numbers like sqrt(2 + 3i), one effective method is to express it in the form a + bi, leading to the equation x + iy = (a + bi)². This requires equating the real and imaginary parts to solve for 'a' and 'b'. Alternatively, using polar coordinates simplifies the process, where r = √(x² + y²) and θ = arctan(y/x), allowing the use of the formula sqrt(r(cos(θ) + i sin(θ))) = √r(cos(θ/2) + i sin(θ/2)). Both methods can be calculated by hand or with a spreadsheet for efficiency. Understanding these approaches aids in quickly approximating square roots of complex numbers without advanced calculators.
jkg0
I have a ton of homework with square roots of complex numbers. Like sqrt(2 + 3i)
What is the fastest way to break these down into its approximates like 1.67 + 0.895i without using a TI89/Maple/Matlab/Mathmatica.
You could just do a general case for x+iy
\sqrt{x+iy} = a+bi \Rightarrow x+iy = (a+bi)^2and then just equate the real and imaginary parts. Though you will have to solve for 'a' and 'b'. Then you could just either put the numbers into a spreadsheet or calculate by hand when you get 'a' and 'b' in terms of 'x' and 'y'.
Or use the fact that \sqrt{r(cos(\theta)+ i sin(\theta))}= \sqrt{r}(cos(\theta/2)+ i sin(\theta/2)).
For x+ iy, r= \sqrt{x^2+ y^2} and \theta= arctan(y/x)
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
