Can a Steel Piping Cubic Bedframe Support Heavy Weight?
A cubic bedframe made from schedule 40 steel piping can potentially support significant weight, but the specific dimensions and design are crucial. Using 3/4" or 1" pipes may be adequate, but additional vertical bars along the frame's walls could enhance stability and load capacity. Calculating yield strengths and load limits requires understanding structural engineering principles, which may not be readily available online. Concerns about horizontal bars and support beam buckling are valid, especially for heavier loads like a hammock for two people. Proper calculations and possibly consulting with a structural engineer are recommended to ensure safety and effectiveness.
Splicel
Hi, so I'm currently trying to build a cubic bedframe out of metal pipes. The frame would essentially be a 7'x7'x5' rectangular prism (HxWxL, I.E. 7x5 being the base of it), with four 1' legs holding it up. However, I would like the top of the frame (The 7x5 square above the bed) to be able to support some weight, ideally like 250 lbs at any given point on the horizontal bars. I was also considering using some tees to add additional vertical bars along the 5x7 vertial walls of the bedframe to give additional support, but I'm not sure how much difference that would actually make.
I was planning on using the schedule 40 steel piping you can buy at Lowes/Homedepot, but the largest sizes were 3/4" and 1", and I wasn't sure if either of those would be strong enough to support this.
I have a bit of a math/engineering background, unfortunately it's all in software and computer engineering, not mechanical or structural engineering. I could not find anywhere online to help with even rough estimates of yield strengths of horizontal steel bars, nor equations I would need to figure it out myself, so I really have no idea how to calculate this. I'm not even sure if I should be worried about the horizontal bars, but instead should be focused on the support beams buckling.
Also, if I did get the 3/4" or 1", what would be the maximum load I could put on the upper rectangle of the frame? Could I make a hammock and support 2 people (~400lbs) upon it?
Thread 'I need a concave mirror with a focal length length of 150 feet'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
