How Does Refraction Affect Laser Beam Diameter?
Refraction affects the diameter of a laser beam as it transitions from air to glass, with the initial diameter being 3.1 mm and an incident angle of 26 degrees. Using Snell's law, the angle of refraction is calculated to be approximately 17 degrees. The relationship between the diameters before and after refraction is established through the equation d1/cosθ1 = d2/cosθ2. Applying this equation results in a final beam diameter of 3.3 mm in glass. Understanding the geometric relationship at the interface clarifies how the diameters are connected.
pinkerpikachu
A laser beam of diameter = 3.1mm in air has an incident angle = 26 degrees at a flat air-glass surface.If the index of refraction of the glass is n=1.5, determine the diameter of the beam after it enters the glass.
n1sinθ1=n2sinθ2
okay, well the initial application of snell's law is obvious. The laser is going from air, where n = 1 into glass where n = 1.5
So, (1)sin(26) = (1.5)sinθ2
θ2 = (approx) 17 degrees or 16.99
I know how to find the diameter of the laser, the solutions have this equation:
d1/cosθ1 = d2/cosθ2
and simple plug and chug would yield the answer 3.3 mm
But I just don't understand where this second equation came from. Can some one walk me through the sense behind it? My book doesn't even mention it, so perhaps its obvious (just not to me).
A picture always helps.
ehild
I see, the two diameters are related through the common interface (the hypothenuse of the two triangles). Just some geometry from there.
It makes sense, thank you :)
You are welcome. And start drawing!:smile:
ehild
