Solve Air Pressure Problem: 500m Skyscraper, 1.3 kg/m3
To determine the air pressure at the top of a 500-meter skyscraper with a constant air density of 1.3 kg/m³ and a base pressure of 1 bar, the relevant calculation involves using the formula for pressure change due to height. The pressure difference can be calculated using the equation P = ρgh, where ρ is the density, g is the acceleration due to gravity, and h is the height. Converting 1 bar to pascals gives approximately 100,000 Pa, and the pressure difference at 500 meters is calculated to be around 6370 Pa. Thus, the pressure at the top of the skyscraper is approximately 0.93 bar. Understanding the distinction between pressure and force is crucial, as the calculations yield pressure in N/m² rather than force.
edanzig
The question asks; "Assuming that the density of air is a constant 1.3 kg/m3 and that the air pressure is 1 bar, what is the pressure at the top of a 500 meter high skyscraper?"
I'm having trouble setting something up but here is what I do have;
Regarding liquids we know that F = (Rho)(height)(g) so I want to say that whatever "causes" the "air to push down" on the ground at 1 bar of pressure should have 500 meters worth of "height" removed from it. So force pushing down = 1 bar and (force pushing down) - 500 meters = answer.
So (Difference in force) = (density)(g)(height difference) where given density is in Kg/m^3, height is in m and g is m/s^2. Summing up these values we get Kg/m*s^2 Which is equal to a Newton. The atmospheric pressure is Newtons/m^2.
If I ignore this discrepancy (because the pressure is measuring F/A, and I'm solving just for the force) and solve to problem I end up with a huge number 1.3*8.9*500 which is obviously incorrect. Can someone please steer me in the right direction? thanks
rho*g*h gives you a pressure not a force.
The question is only asking for the pressure so forget everything about forces. Can you convert 1 bar into kPa?
To elaborate on what paisiello said, your 1.3*8.9*500 is N/m2, or Pa. This is the difference between the pressure at ground level and the pressure at 500 m. What is 1 bar in Pa?
Chet
1 bar in Pa is approx is 100,000. The difference is 6370. Therefore the answer is .93 bar. (thanks) Just not sure when you say that rho*g*h gives pressure and not force, the units sum to "N" and not "N/m^2."
If you do the calculation with all of the units then you will see that it gives you a pressure F/A. And you don't sum the units, you multiply them.
\frac{kg}{m^3}\frac{m}{s^2}m=\frac{kgm}{m^2s^2}=\frac{N}{m^2}
