Solve Work on Inclined Plane for m1, a, h, m2, uk
The discussion revolves around calculating the work done on two blocks connected by a pulley system, with one block on an inclined plane and the other hanging. Key calculations include the work done by gravitational forces, tension, and friction for both blocks as they move a distance h. The total work on the system is derived from these individual contributions, leading to an expression for the final speed of the blocks. Additionally, there is a secondary problem involving three blocks connected in a similar manner, where the goal is to determine the coefficient of kinetic friction for constant speed. The conversation also touches on the importance of clear communication in forum posts.
oreosama
A block of mass m1 is placed on an inclined plane with slope angle a and is connected to a second hanging block of mass m2 by a cord passing over a small frictionless pulley the coefficient of kinetic friction is uk the system is released from rest with block m2 dropping a distance h.
given m1, a, h, m2, uk
calc the work due to each of the forces on block 1 in moving h
calc the work due to each of the forces on block 2 in moving h
calc the total work on the sys and final speed of the blocks
w = F*d
http://i.imgur.com/IxtPw.png
for block1
Wg = -h*mg*sin a
Wt1 = hT
Wn=0
Wff = -h*uk*mg*cos a
Wtot = hT - *mg*sin a - h*uk*mg*cos a
for block2
Wg = mgh
Wt = -hT
Wtot = mgh - hT
hT - *mg*sin a - h*uk*mg*cos a + mgh - hT = 1/2*m*Vf^2 + 1/2*m2*Vf^2 - 0 (start from rest)
sqrt( 2/(m1+m2) * (mg*sin a - h*uk*mg*cos a + mgh)) = Vf
blocks a, b, c are connected as shown. block a,b,c have same mass m and coefficient of kinetic friction between each block and the surface is uk. block c descends with constant velocity. use 30 for angle of incline. given m h uk determine
work due to forces on A moving h
work due to forces on B moving h
work due to forces on C moving h
solve for uk in terms of the other givens for the system to move at constant speed
http://i.imgur.com/DtwxJ.png
block A
Wff= -uk*mg*h
Wt= T1*h
block B
Wt2 = T2*h
Wg = -mg*sin a*h
Wff= -uk*mg*cos a * h
Wt1 = -T1*h
wtot = T2*h - mg*sin a * h - uk*mg*cos a * h - T1* h
block C
Wg = mg*h
Wt2 = -T2*h
Wtot = mg*h - T2*h
T1*h - uk*mg*h + T2*h - mg*sin a * h - uk* mg* cos a * h - T1*h + mg*h - T2*h = 0(constant speed implies vf v0 are the same meaning no change in kinetic energy right??)
-uk*mg*h - uk*mg*cos a * h = mg*sin a * h - mg*h
-uk - uk*cos a = sin a - 1
-uk(1 + cos a) = sin a - 1
uk = - (sin a - 1/ (1+cos a))
uk = 1/2 / (2+sqrt(3))/2
uk = 1/(2+sqrt(3))
want to be sure I am not doing anything horribly wrong thanks for any help.
oreosama said:
A block of mass m1 is placed on an inclined plane with slope angle θ and is connected to a second hanging block of mass m2 by a cord passing over a small frictionless pulley. The coefficient of kinetic friction is μk. The system is released from rest with block m2 dropping a distance h.
given m1, θ, h, m2, μk
calc the work due [STRIKE]to[/STRIKE] by each of the forces on block 1 in moving h
Wow! A little bit of punctuation, etc. sure helps ! ...along with a few other changes.
didnt seem to be an issue on other posts, sorry
Do you mean, in your other posts?
In many of those you did, at least, use periods.
You probably should take a bit of time to read rules for posting in this Forum. Here are two short excerpts.
General Posting Guidelines
...Pay reasonable attention to written English communication standards. This includes the use of proper grammatical structure, punctuation, capitalization, and spelling. ...
Do not hijack an existing thread with off-topic comments or questions--start a new thread.
are you having trouble interpreting what I've typed? clearly not or you wouldn't be capable of correcting it by replacing one word and telling me to use more periods. I think that fulfills reasonable english communication.
now read the last sentence of your post. do you not see the irony?
