Solving a Cart Losing Mass Problem
  • Thread starter Thread starter LondonLady
    Cart Mass
The discussion revolves around a physics problem involving a cart losing sand at a rate of k kg/s while being pulled by a force F. Participants derive a differential equation for the cart's velocity, initially expressing momentum and simplifying it to find the rate of change of velocity. There is confusion regarding the negative terms in the equation, leading to questions about the initial mass definition and setup errors. Alternative approaches are proposed, including a method that yields a logarithmic expression for velocity over time. Clarifications are provided that the initial mass M does not include the sand load, emphasizing the importance of correctly defining variables in the problem.
LondonLady
Hi I have this problem involving a cart which is losing sand
It says:
A cart with initial mass M and a load of sand \frac{1}{2}M loses sand at the rate k kg/s. The cart is pulled horizontally by a force F. Find the differential equation for the rate of change of the carts velocity in terms of k,M and F while there is sand in the cart.
So i said that at t = 0 the momentum= \frac{3}{2}Mv. Therefore
\displaystyle{dp = \left(\frac{3}{2}Mv\right) - \left[\left(\frac{3}{2}M - dM\right)\left(v + dv\right) - vdM\right]}
Simplifying
\displaystyle{dp = -\frac{3}{2}Mdv + 2vdM
Dividing by dt
\displaystyle{\frac{dp}{dt} = -\frac{3}{2}M\frac{dv}{dt} + 2v\frac{dM}{dt}}
As \displaystyle{\frac{dM}{dt} = -k}
\displaystyle{\frac{dv}{dt} = -\frac{4}{3M}vk - \frac{2F}{3M}}
Im confused because of the very negative right hand side of the equation. Did i make an error in the set up at the start?
Thankyou in advance
I hesitate to put this forth since I do so poorly at this type of problem; I hope this doesn't confuse the issue but I took a different approach -- it seems too easy even though I can't see the flaw
M(t) = 1.5*M - kt
a(t) = F/M(t)
v(t + dt) = v(t) + a(t)dt
thus
v'(t) = a(t)
integrate and you get a log expression:
[log(1.5M) - log(1.5M - kt)]*F/k
This gives sane answers in Excel.
When you say 'initial mass M' does that include the load of sand? donjennix's approach looks OK to me (but then again, I'm no physics god so...). Using momentum, we have
dp/dt = d/dt (mv)
and since m and v are functions of time, then
dp/dt = mdv/dt + vdm/dt.
Rearranging gives
dv/dt = 1/m(dp/dt - vdm/dt)
Since F is producing the change in momentum, we can substitute it for dp/dt. dm/dt is just k so
dv/dt = 1/m(F - vk)
As a said, I'm not physics guru so let's see what others say.
e(ho0n3 said:
dv/dt = 1/m(F - vk)
And don't forget that m= 1.5*M - kt or something similar
No the initial mass M does not include the mass of the sand. Thankyou very much for your comments, I will have a thorough read of them now.
