Solving Complex Number Homework: No Value for x
The discussion revolves around the problem of finding the value of x given that cosx - isin2x and sinx - icos2x are conjugates. The initial approach involved equating their moduli, leading to the conclusion that cos2x = cos4x, resulting in potential solutions x = nπ/3 or x = nπ. However, the consensus is that the given complex numbers being conjugates implies not only equal moduli but also that their angles must be negatives of each other. The correct method involves equating the real parts and the negative of the imaginary parts directly, rather than relying solely on modulus equality. Ultimately, the conclusion is that there is no valid value for x that satisfies the conditions.
zorro
If cosx - isin2x and sinx - icos2x are conjugates of each other, then what is the value of x?
Since the given complex numbers are conjugates of each other,
their modulus must be same.
i.e.
cos2x + sin22x = sin2x + cos22x
cos2x = cos4x
On solving, I got x=nπ/3 or x = nπ
But the answer given is- No value of x.
Please help
if z_{1}=\cos x - i\sin 2x,\quad z_{2}=\sin x - i\cos 2x Then, \bar{z}_{1}=z_{2} and we obtain:
<br /> \cos x - i\sin 2x=\sin x +i\cos 2x<br />
Equate and and imaginary parts...
Thanks for your reply.
I already got the solution that way.
I would like to find out what is the problem with my solution.
if the two numbers are conjugates, there modulus must be the same is true.
If two complex numbers have the same modulus, they are conjugates is not true.
I completely agree with you that its converse is not true.
But its already given that the numbers are conjugates of each other so their moduli must be same. ( I'm not applying any converse here)
It's not enough for their moduli to be the same, their angles must be negatives of each other too. And since it gives you that they're conjugates, then you just need to equate their real parts, and the negative of their imaginary parts.
Thanks!
