Solving for Acceleration on an Inclined Ramp
  • Thread starter Thread starter SS2006
    Ramp
The discussion revolves around determining the correct sign for acceleration (a) in the context of a 1kg weight on a 20-degree inclined ramp being pulled upwards and to the left. The key equations presented are -a = t - mgsin20 and a = t - mgsin20, with confusion about whether acceleration should be considered -ma or +ma. The resolution hinges on the definition of the coordinate system and the direction of forces acting in both the X and Y directions. Ultimately, the sign of acceleration is contingent on how the origin is defined and the orientation of the vectors involved. The conversation highlights the need for clarity in coordinate systems when analyzing motion under gravity.
SS2006
I have a 1kg weight on a rmap inclined 20degrees being pulled upwards and to the left
in that motion above(look at dashes only), is it -ma or +ma?
so the equation is
-a = t - mgsin20
or
a = t - mgsin20
I am just wondering if a leeft movement has anythign to do with gravity (A) being + or-
thanks
try looking at it in terms of the forces acting in the X direction and the forces acting in the Y direction. Consider where you place your origin.
Then think about which vectors will be positive and which will be negative.
no no i just want a simple anaswre
i just meant weather acceleration should be -ma or +ma
It has to do with how you define coordinate system.
i have an exam tomorrow and i just wanted to know , are you saying there's no way to tell from the info i sent?
*sigh* nvm..
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
