Solving Friction Problem: Minimum Force Needed
  • Thread starter Thread starter aquila457
    Friction
To determine the minimum force F needed to hold block m against block M without falling, it is essential to analyze the forces acting on both blocks. Block m is elevated and experiences gravitational force, while static friction between the two blocks prevents m from sliding down. Applying Newton's laws, the net force in the y-direction must equal zero for block m to remain stationary. The equation can be set up using the masses of both blocks and the coefficient of static friction. A detailed solution will involve calculating the forces and ensuring equilibrium in both the x and y directions.
aquila457
a horizontal force F pushes against a block of mass m, which in turn pushes against a larger block of mass M. There is no friction between the larger block and the table, but there is friction between the two blocks (coefficient of static friction). What is the smallest force F that will hold m against M without letting m fall down?
f=ma
no idea
I gather that block m is elevated (not touching the table) as a force F is applied to that block which is in contact with block M on the table. Use your relevant equation to set up an equation in terms of F,the mass of both blocks (moving together), and a. Then look at block m alone and identify all forces acting on it. Use Newton' laws in both the x and y direction. In the y direction, there must be no acceleration. Show an attempt at a solution, please.
thanks for the hint; i skipped ahead to some other problems, answer attempt will come soon
