Solving Quadratic Equation: Find the Time
5 replies · 2K views · last reply
intenzxboi
k so i used
x-xo= Vo t + 1/2 at^2
plugged in all my values
then moved everything to one side and used the quadratic formula
here is my question.
when i solve for it i get
t=40.28 and t= 40.58
So which t is my time?
Er.. well, you seem to not have included the actual question?
lets just use imaginary numbers
if u solve for t and get one + and one - answer u know time can't be negative if you are traveling forward.. so the answer is the + one
but what if your t comes out to be both + and you are going foward with -acceleration
This isn't something that has a general rule - sometimes both of them can be the correct time and other times there's some condition that rules the other one out.
Looking at your equation now it's the one used for 2D motion.. Taking that as an example, if you're considering a projectile and get two times it should be because the object is actually at the same horizontal position twice - once when going up and once when going down. It depends on what you want to calculate, in that case.
Probably this is no help, but I honestly can't do much more. Sorry ;/
I actually got it... had to think about it for a while..
my guess is that its the lower time because that's when the object gets there first...
the second time is when v=0 and the -acc. is making it go backwards so it goes back past the same position
right?
Yeah, if you're considering something that's thrown straight up into the air that would be the case, I'd say.
