Solving SUVAT: Finding T from 2.5m/s to 7.5m/s over 45m
  • Thread starter Thread starter benbrooks
    Suvat
To find the time taken for a mass to accelerate from 2.5 m/s to 7.5 m/s over a distance of 45 m, the equation s = 0.5(u + v)t can be used, where u is the initial velocity, v is the final velocity, and s is the distance. Rearranging this equation to solve for time t involves multiplying both sides by 2 and then dividing by (u + v). The average speed is represented as 0.5(u + v), which simplifies the calculation. The discussion emphasizes the importance of improving algebraic manipulation skills for solving physics problems effectively. Ben expresses gratitude for the clarification and is considering additional tutoring for further assistance.
benbrooks
A mass accelerates from 2.5ms^(-1) to 7.5ms^(-1) over a distance of 45m. Find the acceleration and the time it takes to do this.
I know I need to use s=0.5(u+v)t
But I have no idea how to rearrange it to find t, I am useless at rearranging equations.
I got t=0.5(u+v)-s
I know I did it wrong because I have the answer to the questions here, But It's not really what I'm looking for.
I need to know how to do it.
Any help would be appreciated.
Cheers,
Ben
if I gave you the equation y=Ax...could you solve it for x?
The "0.5(u+v)" part of the equation is the "average speed." Quite literally it is one half of the sum of initial and final velocities. If it is written as (u+v)/2 it makes more sense.
But I am guessing (based on the way you wrote the unit for velocity) that your textbook, or teacher, likes to put everything "above the line."
Anyway, to solve for t, multiply both sides of the equation by 2, then divide both sides by (u+v).
Warning: you better get better than "useless" at algebraic manipulation really quickly, otherwise Physics will get impossible for you. This is one of the main features of problem solving. Get tutorial help ASAP
Something in your explanation made everything click into place. I guess the late nights aren't helping at the moment. Thanks very much and I'm looking into getting extra tuition.
Thanks once again,
Ben
