Specific heat mixture, final temp, etc.
The discussion revolves around calculating the final temperature of a mixture of lead and water using their specific heats. The specific heat of lead is given as 0.03 cal/g*C, with 300 grams of lead at 100°C mixed with 100 grams of water at 70°C. The equation used for heat transfer is set up correctly, but an initial calculation error regarding the water's contribution to the heat equation was identified. After correcting the mistake, the calculations were confirmed to yield a valid final temperature. The final temperature of the mixture is successfully determined after addressing the error.
1MileCrash
The specific heat of lead is 0.03 cal/g*C. 300 grams of lead shot at 100* C is mixed with 100 grams of water at 70* C. What is the final temperature of the mixture if the container is insulated.
Q1 = c1m1(Tf - 100) (lead)
Q2 = c2m2(Tf - 70) (water)
Q1 + Q2 = 0
c1m1(Tf - 100) + c2m2(Tf - 70) = 0
9(Tf - 100) + 100(Tf - 70) = 0
9Tf - 900 + 100Tf - 700 = 0
109Tf = 1600
Tf = 14.7*C = no
EDIT, nevermind... 100 x 70 = 700, you heard it here first!
100 x 70 ≠ 700
gneill said:
100 x 70 ≠ 700
I caught it. :redface:
Works out fine now. Thanks!
