What is the Speed of a Proton at Triumf?
  • Thread starter Thread starter erinec
    Proton Speed
To determine the speed of a proton with a kinetic energy of 500 MeV, special relativity must be applied due to the high energy involved. The mass of the proton is given as 938.27 MeV/c², and the correct speed is calculated to be 0.758c, where c is the speed of light. The initial attempt using the classical kinetic energy formula K = (1/2)mv² resulted in an incorrect value of 1.0323c. The relevant equation to use is KE = (gamma - 1)mc², where gamma accounts for relativistic effects. Understanding that "Triumf" refers to a particle accelerator is also essential for context.
erinec
Determine the speed of a proton whose kinetic energy is 500 MeV. The mass of a proton is 938.27 MeV/c2.
K = (1/2)mv2??
The correct answer is supposed to be 0.758c, where c is the speed of light.
Of course, I plugged in the given numbers to the equation and got the wrong answer 1.0323 c. What did I do wrong? What does it mean by "triumf"?
Thanks
You will need to use special relativity to tackle this problem. Triumf is just a particle accelerator.
The formula KE = (gamma -1)mc^2 may be helpful for your endeavors.
where gamma = (1-v^2/v^2)^(-1/2)
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
