Will the Block Move? Understanding Static and Kinetic Friction
A block weighing 45.0N on a horizontal table is subjected to a horizontal force of 36.0N. The maximum static friction force is calculated to be 29.25N, while the maximum kinetic friction force is 18.9N. Since the applied force exceeds the maximum static friction, the block will move, resulting in an acceleration of 0.8 m/s². The relationship between static and kinetic friction is crucial, as static friction must be overcome for movement to occur. Understanding these frictional forces is essential for solving similar physics problems.
debbers111
A block whose weight is 45.0N rests on a horizontal table. A horizontal for of 36.0N is applied to the block. The coefficients of static and kinetic friction are 0.650 and 0.420, respectively. Will the block move under the influence of the force, and, if so, what will be the block's acceleration? Explain your reasoning.
FsMAX=UsFn FkMAX=UkFn F=ma
i don't know how to make the squiggly m so i put in a U
i found out that FsMAX=29.25N and FkMAX=18.9N and a=.8
but it feels like i just plugged things in and i don't really understand how these relate to each other.
The force of static friction is proportional to the normal force of a body. We define the constant of proportionality to be u_s.
Now when you push on a block, it will not move unless you apply enough force. This is because the force of static friction balances whatever force you apply. This is true until you reach a slipping point, which we call f_{s} max.
Mathematically, we'd say f_{s} <= u_{s}n, and we have equality when f_{s} is maximized.
Once you pass the slipping point, you have kinetic friction, and again, this force is proportional to the normal force of the object, and the proportionality constant is defined as u_{k}.
Oh, and keep in mind that the coefficient of either friction u depends on the surface in question. Ice will have a much smaller u than asphalt since it requires less force to reach the slipping point, and takes longer to get a moving object to rest (assuming the applied force is removed right after the object begins to move).
That is just a rough description, there are plenty of resources on the internet that could give you help on this topic.
thanks! that actually helped!
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
