Static Charge Induction: Rod and Sphere Experiment
  • Thread starter Thread starter Ammar Qasim
    Charge Static
The discussion revolves around the principles of static charge induction using a rod and two insulated spheres. When the rod approaches the spheres, positive charges are induced on one sphere while negative charges accumulate on the other, maintaining overall charge conservation. The spheres start neutral, and upon separation, one sphere becomes positively charged while the other remains negatively charged. Participants clarify the movement of charges and correct misunderstandings regarding the final charge states of the spheres. The conversation emphasizes the importance of understanding charge distribution and conservation in electrostatic interactions.
Ammar Qasim
e78-1341-443c-b923-f7d096e7756b&out=http%3A%2F%2Fwww3.0zz0.com%2F2013%2F08%2F13%2F17%2F522810097.png
I think it depends on induction so when the rod is brought close, the spheres will be positively charged. When they move away of it, A will get a negative charge "by induction" and B will get a positive one
Hi Ammar Qasim, Welcome to Physics Forums.
Since the spheres are on insulated stands and the rod never contacts the spheres, charges can only move around, and no new charges will enter the system (conservation of charge). The two spheres start out neutral (zero net charge). Further, charge can only move where there is a conduction path. What does this tell you about the sum of the charges on the two spheres after they are made separate?
When the spheres are in contact and the rod is brought close, make an approximate sketch of the distribution of charges on the spheres. What will it look like?
Hi gneill, thank you for help.
When rod is brought close the positive charge will move to A and the negative charge will move to B then A will be attracted to the rob holding the positive charge so the answer will be letter B. Did I get it ?
No. What happened to the negative charge that you say moved to B? Where does it go if you say that sphere B ends up neutral while sphere A is positive?
gneill said:
No. What happened to the negative charge that you say moved to B? Where does it go is you say that sphere B ends up neutral while sphere A is positive?
Oh, you are right. the negative charge will remain at B so the answer will be letter (A)
Looks good :smile:
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
